  • Replies 447
Hey Rianto,
How much for EBC reds front and rear for R33 GTST delivered to 2112?
Will attend to your inquiry asap, wife just gave birth to our son 2 hours ago!
RDA group buy 48 order list:
- aleks (payment cleared)
- Malz34 (payment cleared)
- G3TFKD (waiting for payment to clear)
- Roland (waiting for payment to clear)
- WTF-33R (waiting for payment to clear)
RDA group buy 48 order list update:
- G3TFKD (payment cleared)
- Roland (payment cleared)
you can send to email: rsoputro at hotmail dot com (replace 'at' and 'dot')
PM also sent....
- mind_riot (waiting for payment to clear)
Terry's order added to RDA group buy 48 list:
- tteerrrryy (waiting for payment to clear)
hi mate. im chasing a rotor with the following specs
324x22mm 5x114.3 stud pattern and with a 190mm hand brake diameter (or as close to as possible)
hub diameter is 60.1mm but thats not really that essential
thinking the 350z track rotors might be exactly what im after (322x22..)
if u can find a more suitable match - can u please send me a pm with prices and perhaps the offset of the brake shoe mateing surface from the back of the hat.
this is to suit a custom setup on an ma70 supra.
cheers
Edited by DCIEVE
350Z brembo version has 322x22mm at the rear. 324mm is the front, no rears have 324mm, only 322mm if this is what you mean?
The 324mm is for the front and the thickness is 324x30mm
The total hat height for the 350Z rear 322x22mm is 62.5mm (or 40.5mm if you exclude the rotor's thickness) not sure if that is the right offset you want?
However there are no mention about 190mm hand brake diameter.
Let me know if this match the spec that you want. I don't have data on brake shoe mateing surface, sorry.
sorry, did mean 322mm.
i read this on one of your other posts and gave me the impression that some nissan car/version has 190 mm park brake, which is what i require.
17. V35 Skyline / 350Z track brembo: Available in EBC Gold F=GD7122 324mm, R=GD7123 322mm or RDA Gold F=7685G 324mm, R=7689G 322mm
(Fits all V35/350Z 2003-2004 coupes with Brembo Calipers)
18. V35 Skyline / 350Z late model 2005~ update: F=7965G 320mm, R=7966G 308mm (NOTE: V35 need to upgrade rear park-brake drum shoe to 190mm diameter)
pm sent.
Regarding that note, it's because I've sold non-brembo rear rotors & brembo size rear rotors to early V35 without problems.
Apparently they are all straight fit / interchangeable with 350z.
However I had someone finding out the expensive way that the rear 350z late model 308mm rear rotors do not fit because
he had 170mm rear park drum brake. So apparently either:
a) JDM V35 has smaller 170mm park brake from 2005 onwards; or
b) 350z has bigger 190mm park brake from 2005 onwards.
I have no idea which one of that possibility is true.
If a) is true, then it will solve your problems because that means all rotors for 350Z are produced with 190mm rear park brake allowance.
If b) is true, then the rotors you are gonna order will have a clearance only enough for 170mm park brake...
Update - added fat200sx order & all other payments cleared
- WTF-33R (payment cleared)
- mind_riot (payment cleared)
- tteerrrryy (payment cleared)
- fat200sx (payment cleared)
Basho: quote sent..
blyl: check your pm - I need your delivery details to avoid any delays...
- blyl (need delivery detail)
Are the rotors on it came off R32 GTR or are you just using the R32 GTR calipers?
If the rotors are off a R32 GTR, you can measure the front one's diameter across. If it's 297mm (around 30cm) then it's the early models 89-93
If the rotors are 324mm (around 32 1/2 cm) then it's off a 93-94 late V-Spec II model.
Hope that helps...
Hi
Finally got my measurement, it's similar to the early model but I got it in 290mm.
Now I wonder I might only have the R32 caliper so is that mean any r32 early model rotors would fit for my car.
Thanks for your help
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
    • Ye, in terms of bolting up the "Conversion" from a GT to a GTT is effectively "Use GTT parts for everything" Except the subframe itself, because you won't want a HICAS/4WS subframe. Remember your ABS system will be different too, thanks to GT being the S15 3 sensor system, instead of the R34 4 sensor system for wheel speed. I do not know how people get this to work given R34 diffs do not have a provision for an ABS sensor (they are on the tone wheels of the axles). I assume***** people use S15 gear/R34NA forever when they realize this - Or they convert it to a rear diff/axles that are R33 style which I presume has the singular speed sensor on the diff itself, but then you have to wire it all in and...and... and...
    • Foreshadowing was never so easy.
