  • Replies 447
Glad to hear.
Killabeez, check your pm. Yes S13 rear is available.
Musky, the choice for upgrading the rear or not is totally up to you. I had front slotted on my old R33 Gtst and std rear as well. No problems.
Could I please get a quote for Front slotted + Rear slotted rotors and Green EBC pads all round for a R34 GTT? Ship to Adelaide. Thanks.
gday mate
um ive got an r34 gtt
wondering how much all up to get Grooved Dimpled on the front and standard slotted on the back both with pads will be sent to adelaide, 5108
thanks mate
oh thats a decent price um when will the next groupe buy be after that one mate?
um brakes not really in this months budget
no problems
next group buy some time in early July.
if you go to My Controls, upper RH corner, then on the left sidebar go to Board Settings, make sure the "Disable Personal Messenger" section is set to No.
Setting it to Yes will disable your personal messenger.
if still doesn't work, email me: rsoputro at hotmail dot com
(replace the obvious words above with the proper symbols, you know the drill - spam prevention)
i'll send you a quote soon.
Hey bud, after current pricing on front slotted; and for both plain and slotted for rear rotors. To suit R33 GTS-t. Delivery to 4108.
Cheers
Edited by N-DAWG
Hi, is there anyone online who can tell me in the next 5 minutes how the hell to get the rear rotors off an R34GTT? Otherwise I am taking to it with a slegehammer. I assume the handbrake assembly is inside the top hat and I somehow have to undo that? Please help ASAP. I have the car in 1,000,000 pieces right now and want to get it back together.
release handbrake. handbrake drums might be pressing the inner drum of the rotors, making it too tight to remove.
it can get sticky, from all those age old rust and dirt and grime get stuck in between. use rubber mallet. sledgehammer is a bit extreme... :-)
Yeah I released the handbrake. So there are definitely no other nuts/bolts to remove once the brake caliper is off? Just bash the bit of the disk you can see? Trouble is with the shield around it there is not much room to swing or hit.
Damn - might jack it up as high as it will go and get some leverage on the mallet. Thanks! It doesn't seem to have much movement at all - I take it it will gradually loosen up and come off?
Well I have just finished putting it all back together.
In the end I gave up on the getting the rear rotors off - making the necessary noise at 11pm seems like a bad idea in my neighbourhood.
So, today I did:
- Fitted front RDA slotted/passivated rotors
- Fitted front QFM HPX pads
- Fitted front and rear ADR compliant braided brake lines
- Flushed entire brake system with Motul Dot5 and refilled/bled
- Painted all calipers gold
Phew - 9.5 hours all up.
The result is below
Guest
    • These are small points I should actually add to my original post. GKtech makes an extended slave line for this conversion. It's what I use, and it works well. You'll also need a CD009 slave cylinder.  S/R Chassis Z33/Z34 Conversion braided clutch line As for transmission sensors, you'll need to both extend the wiring and replace the connectors. I can't recall which is which, but one is your neutral switch and the other the reverse switch. As they are just switches, just test for continuity with your transmission in neutral or reverse to figure out which is which. Connectors:  VQ35 neutral Switch Connector | Wiring Specialties VQ35 Reverse Switch Connector | Wiring Specialties
    • I’ll try and see it could be the release bearing. As for the 4th gear grind maybe clutch doesn’t disengage properly cause it is slightly like very slightly hard to go into first could be due to the slab cylinder pin being short uni clutch is a twin plate.   Ive attached some assembly photos hopefully you can open the link and see maybe detect what’s wrong https://share.icloud.com/photos/0dc2YvW__Hl6jl-l2_0jejjpg https://share.icloud.com/photos/09e0jkWOK-vP48c1cfY6u3ViA https://share.icloud.com/photos/0b4rDmh5R7pK7fb1VtND73a3g https://share.icloud.com/photos/05eeUi_6dC4DVi80jOUYDgb0g https://share.icloud.com/photos/06335TgY1XxyIJal_wkdQLhzw
    • Yeah for sure that is peddle adjustment
    • What are your thoughts on this after having it for a while, worth getting?
    • Downshifts are harder on transmissions than upshifts, the input shaft naturally slows down once disconnected from the engine so the synchros aren't doing all the work. There's no "natural" tendency for an input shaft to increase RPM. Something is not right there, I don't have a great answer on what. You can try a dedicated GL4 75W90, I plan to switch to Motorcraft XT-M5-QS which is supposedly a very good 75W90 for NB Miatas which have a weirdly sensitive transmission from the factory. I would chase down why your clutch is making a hissing noise, that's not normal. It might be no big deal but in the absence of anything else to investigate I would look at that.
