  • Replies 447
ok, hope I hear some news by tomorrow if not Friday.
if RDA brand not available you may get EBC D7122 & D7123 of the same quality & fitment in slotted.
Hey Rianto
could i please get a price for
Front and Rear standard slotted rotors
which pads would you recommend for daily use? Green or Red?
thanks mate
Jaye
Hi Rianto,
I received mine today.
They are the EBC (GD 7122/7123) Turbo Grooved ones. They look awesome.
These are not the gold passivated ones.
Should i still paint the Hat (Hub) to avoid rust?
Any help would be great.
I wouldnt' suggest painting it, as they may not look nice when they start to peel off. and it might be tricky not to get any paint layer on the hub contact point between your rims and the hub or the friction area where the pads contact...
plus they'll be behind the wheel most of the time it's not really that obvious whether surface rust is forming or not, as long as you use your car regularly that shouldn't be an issue, if not keep it in a garage/shed to reduce the moisture from overnight dew.
but if you want you can always paint the hub if you like. I can't stop you :-)
oh yeah, druz, i think based on your order it was suppose to be slotted in normal non-gold finish, but since they can't find RDA in stock, they use EBC which comes in grooved pattern but has normal non-gold finish. so in a way you kind of getting a little 'bonus' in the form of the slot & dimple patterns.
Guest
    • Means something is not set up right, tune/calibration related.
    • Finally replaced the previous temporary mesh indicator surrounds (temporary was the last 10+ years 😂) with a 3D printed GTR style version for the front indicators. I think it looks a lot nicer than the old setup and at least the indicators now point in the correct direction rather than angled off. Needed a little bit of tweaking to deal with the intercooler piping but got there in the end. Old and new photos below.
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
