  • Replies 447
Rianto, Just a quick note that i recieved my pads and rotors, thanks for organising another successful group buy!
To those thinking about getting EBC brake pads, I highly recommend the redstuffs and the RDA slotted rotors!
noticed some post missing since the past 2 days...
Update to RDA Group Buy 49 order list: (Closing 7th Aug)
- keii (payment cleared)
- Moodles2 (payment cleared)
- 180 wanabe (payment cleared)
- DriftGTS (payment cleared)
- PhilKenSebben (payment cleared)
- FOOLBOOST (paypal payment cleared)
- br3ndan (waiting for payment to clear)
- BASHO (waiting for payment to clear - R34 GTT clutch)
matt, check your pm. what car is it for?
- br3ndan (payment cleared)
- BASHO (payment cleared - For R34 GTT Clutch kit)
Rianto - When this one is done - can you start a new thread mate?
Its easier for Admin to keep track as there have been some wayward GB's over the past 6 months so we are trying to clean up the section with a bit of policing and more closer/strict rules.
So once the GB is over (as per the start/end date), just start another thread and i will come along and close the previous ones.
Thanks for the GB's, i've left you feedback from my rotor purchase late last year too, i forgot to do it lol :angry:
no problems :devil:
Hi, Can you please let me know how much rotors and red pads are. I have a 2004 V35 350GT. Also are you able to get red calipers?
Delivery would be to Flinders, NSW 2529.
Thanks.
Hi Adrian,
I don't sell calipers, sorry - you could either get a can of heat resistant paint and paint your caliper, or browse the net for a set of red calipers.
Does your 2004 V35 have brembo calipers?
Let me know - cheers.
- shnoog (payment cleared)
- Chi100188 (payment cleared)
Hi Adrian,
Hi, I dont think they are Brembo. They are just a charcoal/silver colour. Cannot see any branding on them.
Hope that helps.
Adrian
Guest
    • These are small points I should actually add to my original post. GKtech makes an extended slave line for this conversion. It's what I use, and it works well. You'll also need a CD009 slave cylinder.  S/R Chassis Z33/Z34 Conversion braided clutch line As for transmission sensors, you'll need to both extend the wiring and replace the connectors. I can't recall which is which, but one is your neutral switch and the other the reverse switch. As they are just switches, just test for continuity with your transmission in neutral or reverse to figure out which is which. Connectors:  VQ35 neutral Switch Connector | Wiring Specialties VQ35 Reverse Switch Connector | Wiring Specialties
    • I’ll try and see it could be the release bearing. As for the 4th gear grind maybe clutch doesn’t disengage properly cause it is slightly like very slightly hard to go into first could be due to the slab cylinder pin being short uni clutch is a twin plate.   Ive attached some assembly photos hopefully you can open the link and see maybe detect what’s wrong https://share.icloud.com/photos/0dc2YvW__Hl6jl-l2_0jejjpg https://share.icloud.com/photos/09e0jkWOK-vP48c1cfY6u3ViA https://share.icloud.com/photos/0b4rDmh5R7pK7fb1VtND73a3g https://share.icloud.com/photos/05eeUi_6dC4DVi80jOUYDgb0g https://share.icloud.com/photos/06335TgY1XxyIJal_wkdQLhzw
    • Yeah for sure that is peddle adjustment
    • What are your thoughts on this after having it for a while, worth getting?
    • Downshifts are harder on transmissions than upshifts, the input shaft naturally slows down once disconnected from the engine so the synchros aren't doing all the work. There's no "natural" tendency for an input shaft to increase RPM. Something is not right there, I don't have a great answer on what. You can try a dedicated GL4 75W90, I plan to switch to Motorcraft XT-M5-QS which is supposedly a very good 75W90 for NB Miatas which have a weirdly sensitive transmission from the factory. I would chase down why your clutch is making a hissing noise, that's not normal. It might be no big deal but in the absence of anything else to investigate I would look at that.
