How thick is your overall rear rotor diameter? according to RDA's catalogue, the rear R33 non turbo has an 8mm rear rotor thickness, being so thin, it is usually made as solid disc. There were a few ppl bought RDA7692 with 8mm thickness and it fits ok to rear R33 non turbo...
  • Replies 447
rotors on car are 15mm thick, supplied rotors are 10mm thick (there 8mm on the end due to a 1mm tapered lip on each side)
so 5mm thickness difference
ps all other dimensions are identical though
That must be because the old RDA7690 is no longer in production... that was 15mm thick, and was officially for a R32 GTS.
RDA catalogue only have RDA7692 listed that will fit within your rear caliper... 15mm vs 10mm is only about 2.5mm less on each side
so should be no problems... there were a few other R33 non turbo owners who bought RDA7692 previously and they didn't have problems fitting them on. if you do, let me know.
Cheers, Rianto
quote sent....
Group buy 44 update:
- nightcrawler (payment cleared)
- mccready (payment cleared)
- tteerrryy (payment cleared)
all 3 payments cleared
quote sent....
- runnin4life (waiting for payment to clear)
- -slide- (waiting for payment to clear)
- runnin4life (payment cleared)
- -slide- (payment cleared)
All 5 payments cleared
- Dohmar (waiting for payment to clear)
closing this weekend!
Got your order...
- Delta Force (waiting for payment to clear)
possibly a stupid question... but can you oversize the rotors and order GTR's one for a GTT?? or do you need bigger calipers to match?
the rear discs on my car (standard) just look pretty damn small...
no it's not stupid question.
it is possible, but the onus lies on you to fabricate or get someone to fabricate caliper adapter or finding an adapter to suit. mind that R34 GTT rotor's hat height could be different to GTR, so the position of the rotor might be different and you may need to consider the repositioning in addition to the diameter difference...
- Dohmar (payment cleared)
- Delta Force (payment cleared)
- SO17K (tbc)
- R33 Smash Daemon (tbc)
apparently the difference is very little, this is from a friend who was looking at the RDA line-up
"Hey do you know if the GTR rotors fit your Skyline? As far as i can see from the spec sheet they GTR ones are 324mm vs 310mm and th eonly other difference is the GTR ones are 53.8mm high vs 53.75mm..."
so that's a .05mm difference, which doesn't sound massive.
I'll start a thread in the braking section to see what people think, if it's not a huge job it might be worth getting bigger rotors if the price isn't much different.
Actually, is the price much different between standard slotted front/rear for the GTT and GTR?
probably not worth the hassle Daniel .. I'm sure Nissan engis knew what they were doing when they decided on the rotor sizes. Besides most of the braking is at the front due to the weight of the engine which is why the discs are bigger at the front. Slotted rotors should give you better than stock braking anyway.
don't know much, but i'd imagine bigger discs would give you better heat resistance as there is a greater surface area to dissipate the heat, and if there isn't much to modify and the prices are relatively similiar, could be a cheap upgrade ontop of the slotted upgrade
price wise front R34 GTT & R34 GTR is the same
but the rear R34 GTR is the same as the front (in slotted) and the R34 GTT is cheaper at the back.
R34 GTR front 324mm rear 300mm
R34 GTT front 310mm rear 297mm
It's only 14mm difference at the front, it's probably not worth mocking around with caliper adapter and stuff for such a small upgrade.
Unless you have an R33 gtst with 296mm front then some people upgrade this to a gtr front as there is more difference in size at the front.
Guest
    • I’ll try and see it could be the release bearing. As for the 4th gear grind maybe clutch doesn’t disengage properly cause it is slightly like very slightly hard to go into first could be due to the slab cylinder pin being short uni clutch is a twin plate.   Ive attached some assembly photos hopefully you can open the link and see maybe detect what’s wrong https://share.icloud.com/photos/0dc2YvW__Hl6jl-l2_0jejjpg https://share.icloud.com/photos/09e0jkWOK-vP48c1cfY6u3ViA https://share.icloud.com/photos/0b4rDmh5R7pK7fb1VtND73a3g https://share.icloud.com/photos/05eeUi_6dC4DVi80jOUYDgb0g https://share.icloud.com/photos/06335TgY1XxyIJal_wkdQLhzw
    • Yeah for sure that is peddle adjustment
    • What are your thoughts on this after having it for a while, worth getting?
    • Downshifts are harder on transmissions than upshifts, the input shaft naturally slows down once disconnected from the engine so the synchros aren't doing all the work. There's no "natural" tendency for an input shaft to increase RPM. Something is not right there, I don't have a great answer on what. You can try a dedicated GL4 75W90, I plan to switch to Motorcraft XT-M5-QS which is supposedly a very good 75W90 for NB Miatas which have a weirdly sensitive transmission from the factory. I would chase down why your clutch is making a hissing noise, that's not normal. It might be no big deal but in the absence of anything else to investigate I would look at that.
    • ^^ It's a valid point. Sometimes you (and in this case, I) stand too close to the problem to see the solution. The oil control thread eventually came to a recommendation about running lines from cam covers and sump to the catch can.
