hey everyone, i need some advise.
i would just like to know if it is normal for the oil pressure guage to fluxuate whilst driving......
if i am idling it sits n about 1kg/cm squared
if i am reving a littly it sits on 2kg/cm squared
if i am driving quite hard it sits on 4kg/cm squared.
but i am a bit worried, when i look down and its on zero sometimes.. i checked my oil, its fine.. what could it be. just a poor guage? or is there a problem it could have?
one other thing... i am getting a major car service tomorrow.. and i was wondering if there was anything i should recommend or ask him to do. like, is there any particular motor oils that you think is good for my car or just anything that i could ask for that is a little better quality for any part of the service...... let me know please..
any suggestions are appreciated. thanks
ashleigh
https://www.sau.com.au/forums/topic/251350-oil-pressure-help/
maybe get them to check your oil pressure with a mechanical guage. they will temporarily remove your sender and put their guage in and check it that way..
ahhhh yeah good idea, thanks...... =]
no wrries the guy is looking at it today so ill go from there and if it is the sender ill prolly get a new guage anyways... would the gtr middle console part with the guages fit in my gtst?
Edited by RRB20ASH
Don't be too fussed about it.
On start up its quite high almost up to 8 on a cold day.
The readings you have mentioned is pretty much normal.
As Cronic has said, just get an aftermarket one just to be sure.
hey all. got my service done. my air flow metre was goOne and he replaced that and now it doesnt misfire at all. yayz.
all up this was the reciept
carry out service and check over---------------$40.00
environment levy------------------------------$5.00
diagnose faulty air flow meter-repair wire plug---$120.00
Labour----------------------------------------$80.00
Tax $24.50
Total $269.00
Is that about right for a major service?
    • Curious if you've discussed this with them, maybe they can remove it for you since you requested it not to be coated.
    • Thanks Rezz...   👍
    • Grind them off, drill them out. Repair any rust on the other side. Start again from scratch.
    • Big R34 GTR parts cleanout. I have a lot of stuff collected over the last 14 years and my missus is giving me hard time. Make my life easy.   Nismo GT carbon fibre diffuser fins (discontinued)  NEW  $2900 Garage Defend Stingray canards carbon fibre  NEW  $1300  Top Secret G Force carbon fibre front diffuser  NEW  $2000  Haltech Elite 2500  NEW  $2500  Haltech Platinum Pro R34 GTR   USED  $1400  Apex’I power FC D'jetro + hand controller R34 GTR   USED  $1400  Nissan OEM BNR34 ECU  USED   $1000  HKS EVC 6  USED  $600  Blitz dual SBC ID boost controller.  USED  $350  TRE 255 LPH Fuel pump  NEW  $100  Fujitsubo  Super Ti exhaust  USED  $2700  Tomei Expreme Ti exhaust  USED  $2000  Trust stainless steel front pipe  USED  $1000  Apex’I super suction kit  USED $400  BC BR coilovers  USED  $600  Hardrace front upper camber kit. USED  $300  Garret 2860-5 turbos –  one good, one needs reco USED  $1000  Nissan OEM Toshiba MFD Screen replacement  NEW  $450  Nissan OEM BNR34 Series II front passenger seat  USED (mint) $5000   Nissan OEM BNR34 front bar in TV2  USED  $1000  Nissan OEM BNR34 front lower air spoiler  USED  $900  Nissan OEM BNR34 front lower air spoiler (painted)  USED  $900  Nismo front indicator (clear) USED  $80 Nissan OEM BNR34 radiator  USED $500  Nissan OEM BNR34 turbos  USED  $500  Nissan OEM BNR34 intercooler USED  $800  Nissan OEM BNR34 front swaybar   USED  $500  Nissan OEM BNR34 intake pipes   USED  $400    Also have a square set of uber rare Volk CE28n in 19*10 +22. Not really keen to sell these but make a high enough offer and maybe I will. If you don't know how much these usually sell for don't bother.   PM for pics.  Pickup Chadstone VIC or postage at buyer's expense.
