Big HELLO to you all,
I have been directed this way by Green_Ghost on boostcruising (Myles). First of all just wanted to say a massive THANK YOU to all who have contributed to the stagea D.I.Y and F.A.Q section, it has been a massive resource tool for me, so once again, THANKS !!!! I have been reading alot lately :ermm:
I recently purchased a 99 Stagea RS4-S with a few mods. It has 3" Stainless catback with Jasma muffler, k/n pod, earthwire kit, HKS SS BOV, HKS hipermax performance suspension, asea rear strut bar, 18" HP Wheels on 235 gemstones and an apexi turbo timer. What a fantastic car to drive, the rear LSD seems so tight, in the wet it's incredible fun.
One question i have though, When i am doing say 100kph on the highway, and i back off the throttle, my A/F ratio heads to 20 and you hear a pop in the exhaust. IF i push the clutch in, my A/F stays at 14-14.5. I first thought it was because the BOV was not plumback, but today i fixed that, and still no joy :thumbsup: Any ideas or is this normal ? I am sure it is contributing to the black soot that ends up powderising the rear end after a week.
Anyways, heres a few pics to show what i got, and would love to meet up with other owners out there
Cheers
Jez
EDIT: Damnit i meant to post this in the STICKY: qld newbies.... ultimate noob now :|
Edited by Jezboosted
https://www.sau.com.au/forums/topic/251362-new-to-sau/
Thanks for the welcome fella's ! Nismo_Boy, I will have to pass up the Dinner meet this time but thank you very much for the invite. looking at going to willowbank either 22nd or 24th if any of you will be out there ?
https://www.sau.com.au/forums/topic/251362-new-to-sau/#findComment-4353066
    • A few more recent pics
    • full send the cnut, do this   fark the wrapping and/or stick on siet. These guys are the ones to go to: https://www.realthermo.com.au/
    • Just had a look, they don't. Fuelling on the base map is purely alpha-N, and the ignition table is MAP. Remember it's just a base map to get the car moving
    • Hi everyone, I’m Dave from Canberra. Here's a few pics of my 1992 R32 GTST coupe which I imported back in 2006. Only mods so far are HKS Hi-power cat back exhaust, K&N filter, ATC Volanti steering wheel, Pioneer stereo, amp and sub. This was my daily driver up until 2015 and sadly hasn’t been driven at all in the last 5 years due to marriage, work, and kids taking up most of my time and spare cash.As such its in need of a bit of TLC and one of my goals for this year is to get it back to running condition and maybe look into club/historic rego. I’ve joined SAU so I can ask a few questions along the way (although I promise to google Current Problem +SAU beforehand!)
    • From talking to the mx5 guys the NC doesn't actually need bonnet vents like the earlier NA and NB models, due to a better designed cooling system and undertray design There's plenty of them used as street cars and weekend track toys running anywhere from around 170 to 250kw with stock non vented bonnets, I initially was going to get some bonnet vents, but, as they are not actually required, I'll put vents on hold for a while and just monitor temps, though I do need to get something to actually monitor engine oil temps though, coolant temp can be pulled from the OBD2, but the oil gauge in the car is not actual oil temp, it is only a calculation based off coolant temp and RPM ☹️ They do recommend upgrading the radiator, which I have already done with a triple pass, and the only other thing they recommend for a street car is heat management, like I talked about above to protect bits in the engine bay from radiant heat, and to either replace the nearly 20 year old plastic coolant expansion tank, which I have done, or get a aftermarket alloy jobbie for some bling They did also say that if I wanted to track the car on occasion a oil cooler and sump baffle would be required, and as I already have had a sump baffle installed when the engine was out......... I'm going to get a oil cooler with a thermostat....... just in case I do eventually track the car, but probably not, but still maybe...🤪
