Hey,
I recently bought a decent head unit, amp, and 4 speakers for my car. Just wanted something better than the stock setup to listen to some nice music while driving.
A friend of mine offered to install it all for me and I took him up on the offer.
Problem is there are some things are stuffed and i don't know what I should do.
I'm not going to persue it with him, so what would you do?
Problems are...
- Clips that hold door trim on are broken so it just flaps when the door is open.
- Clip to hold heater controlls broken so it just flaps around.
- Clip to hold tailgate together (it's a wagon) broken so it flaps around.
- Rear left speaker makes quite a loud hissing sound when the car stereo is on but the car is not running. This turns into a buzzing noise when the engine is running. Any idea what this could be?
- Speakers in the rear seem to be vibrating a lot. So sounds is crap, that could be to do with the panels not clipped together.
I figure i should take it to a proper car audio place to get it all done right, but then what about the broken clips i need? They will charge a fortune to get them and install them all.
Or should i take it to the dealership and get them to try and fix it?
Otherwise is there anyone in adelaide who is reputable that would be willing to assist me (of course you will be paid)
Let me know guys, as i hate driving around in a car that has stuffed up bits.
https://www.sau.com.au/forums/topic/251373-dodgy-install/
New clips from dealer or wrecker, but you will find yours are probably just bent, and/or mis-aligned and not locked in.
Get the stereo system re-installed by someone you TRUST or a decent installer, as you cant rely on wiring and other stuff being right (especially with noises from the speakers).
Try not to rely on mates to do installations unless they have background experience and people to speak to about their work (not wortk risking a friendship over dodgey work).
B.
https://www.sau.com.au/forums/topic/251373-dodgy-install/#findComment-4352474
Hissing while car is on, is the alternator noise.. Get a noise filter installed.. Can get one from Jaycar.
Secondly, rear speakers bouncing ? Make sure all the screws are tight and securing the speakers to the base / panel that its on.
Make sure the panel itself isnt dodgy and running around.
You didnt mention anything about the amp, how is the amp mounted ?
The clips would be around at a wrecker or dealer, try ripping the trim open first, i found most my clips just fell inside lols.
Take your time, tune your headunit aswell.
Would help if you stated what gear you have man.
Let us know.
For some more advice or stuff that we cant answer, ask Chris Rogers.. audio guru. :P
MRXTCZ
https://www.sau.com.au/forums/topic/251373-dodgy-install/#findComment-4352934
kk it's a 1997 TF magna wagon (i used to have a r34 but gave it up to get another motorcycle)
Parts are as followed
Sony amp XM-ZR604 600 watt jobby to power the four speakers
Sony head unit CDX-GT572
Sony 6 x9 3-way speakers rear
Sony 16cm 2-way speakers front
After work tonight i disconnected the rear left speaker cable at the amp. This made buzzing noise go away completely. No there is no feedback through any of the speakers.
Listening to the car now you can hear the speakers vibrate in the door trims and still in the tailgate. I'd put that down to shitty installment.
Mighty pissed off i am.
https://www.sau.com.au/forums/topic/251373-dodgy-install/#findComment-4353902
ok
amp under passenger seat ( it fits nicely.) ground it on the foward seat mounts - there is a screw/10mm bolt hole there- grind the paint back and earth to that point. RCA leads run toward the radio panel and centre console. speaker wiring can follow. thats not a really big unit so the stock wirng is fine.
power can run through the grommet in the passenger kick area and back into the engine bay.
speakers- I'd be surprised if they were sealed at all. mitsi used a 6.75" speaker in the front doors and the sony ones are 6" with 6.5" mounts on them. if you have the originals make a plate up for them and drop the sony speakers into that.
rears - one of them is touching ground for a start. I'm surprised that amp didn't die.
they rely on a seal from the grills to work properly. no seal = crap sound.
as for clips - mitsi - they are all of 50c each. get all the ones that are broke. forget the wrecking yards. most of those are stuffed anyway.
how was the radio mounted?
if its cradled where was it earthed? hopefully to the dash frame and not via the radio antenna.
also the heater controls are one piece held in with two semi hidden screws in the top of the ac panel. they DO NOT have to be pulled to bits to get the radio out..
do you have dash lights?
https://www.sau.com.au/forums/topic/251373-dodgy-install/#findComment-4354006
spot on there chris!, MR XTC suggested using a noise filter to get rid of the alternator whine. dont use one,they are a bandaid fix to a problem that should never of been there in the first place.re grounding your amp and making sure the RCA leads are run properly will fix this problem. how ever if it was a dodgy earth on the head units end that can cause the kind of noise your talking about too.
the TF magna isnt the most easy car to pull apart for begginers.....atleaset thats what iv found when they have been brought to me from people that have attempted them.they just seem to break everything, especially around the headunit area.
https://www.sau.com.au/forums/topic/251373-dodgy-install/#findComment-4359826
ok
To ad to those comments, make sure the power wires from the amp are not run with the rca or speaker wires, that would cause the buzzing.
Edited by W0rp3D
https://www.sau.com.au/forums/topic/251373-dodgy-install/#findComment-4363999
kk well i bought a filter that completely eliminated the buzzing noise. Now as someone said that was a band aid fix so i'm getting the clips this weekend and will check all the ground wires.
He also had the amp setup in correctly, so i changed the switches on it, and now it sounds a million times better. he had also screwed with the gains on the head unit so putting those back fixed it up as well.
So really once I get all the clips done and fix up these earthing problems i should be hunky dorey.
Thanks for all your help I really appreciate it!!
https://www.sau.com.au/forums/topic/251373-dodgy-install/#findComment-4370634
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
