MY Kaaz sounds like its tearing itself to pieces!
Its was making BAd noises from the begining, as soon as i reversed out of the shed and turned it was doing it... i had to drive around 15k to get to a car park to run it in, but i drove sensibly...
when u go round a corner with the clutch in it makes a bit of a whiring noise.. that i expect.. but as soon as u are driving normally it doesnt sound happy at all....
(sounds like the thing is skipping splines on the axel... and no its not.. i checked.. twice)
https://www.sau.com.au/forums/topic/251390-noisy-as-fark-kaaz-2-way/
I had the Kaaz stuff in it, then i changed it because u are supposed to after run in.. so i put the reccomended stuff in it.. (cant rember off the top of my head) I was gunan get some more kaaz stuff but dont wanna waste $100 worth of oil if its not gunna fix it
if you have put redline diff oil in then this could be your problem, the oil is too thin for the kaaz diff and results it becoming very noisy; when did it start making the noises?
Ive got a kaaz 1.5 way with about 1500kms on it, and im not happy with the clunks and grinding noises either. Im thinking of pulling it out and putting a standard one back in. I changed the oil after run in with more kaaz oil, and the diff became a bit quieter, but still feels as though the rear cradle is dragging on the road when in car parks. I f**kin hate it at the moment.
I changed the oil in mine yesterday and put some Penrite Competition diff oil 140w in it and it is ten times better! still makes afew noises but nothing like it was!
So did you have the recommended Kaaz oil in it before you changed to the Penrite?
Ive heard that the Penrite seems to quieten them down a bit. When you say "a few noises", do you mean clunk!, clunk! around tight corners in car parks, or just slight grinding noises.
Thanks,
Shaun.
Toughen up people!
If you wanted a quiet diff you should have stuck with a viscous LSD.
I have changed the oil in my KAAZ diff twice, both times using KAAZ oil, each time it has quietened down a little. I am due for a third and final oil change, which will be done shortly, using a Castrol oil, which has been recommended by a friend using the same diff.
All mechanical diffs will be noisy as you accelerate gently through a corner, if you don't like the feel/noise just push the clutch to eliminate the drive force to the diff. I just don't worry about it.
Thanks,
Shaun.
REALLY bad clunkingnear on grinding noises.... One of a mates has a Kaaz and its quiet compared to mine.. mine sounded like it was tearing itself to bits!!
now with the penrite it just makes a few noises in carparks etc.. that i can live with.. very happy now!
  Al said:
Toughen up people!
Mate it doesnt worry me a f**k if it makes a few noises.. but this wasnt right at all.. it made more noises than a auto locker... now with the new oil its spot on!
I wouldnt recomend the castrol oil, ive got a nizmo 2 way and had the castrol stuff in there, wasnt to bad but later on i changed to penrite 90 weight stuff and it it heaps smoother, still clunks and stuff but i dont mind that :P
might be different to the kaaz ones, seems like you guys are all using a much heavier oil
Edited by s13_Skyline_inside
2way LSDs are very aggressive and thanks to that will always make a noise and theres almost no way of drowning the sound completely but at least when your cornering you tend to forget about the noise. tho, i gotta admit the noise is annoying.
from what i heard from some, the nismo 2 way and the tomei technical trax 2way are quieter than the rest.
  • 4 weeks later...
these diffs are supposed to make noise it feels like the whole cradle is moving and ready to drop out but if you don't want the noise then get a stock car i'm pretty sure all of these things ultimately have the race track in mind and that's where they are supposed to be used hence the lack of quietness if ya don't like it stock is the way to go mine sounds like crap but if ya want it you put up with it still works a treat oh and i use motul oil essentially the same as nismo oil just without the nismo and price tag
    • I'm hoping I just don't have to do an engine rebuild NOW. Doesn't mean I won't do it at some point. I think a plus point is that the car presumably ran on or close to stock power nearly all it's life so far. Only the Owner I bought it from actually increased power with a standalone ECU and blew the OEM turbos. And after it got thee 2860s it wasn't driven an awful lot either.   That is what I meant. With the twins coming on so late (4500-5000rpm) I hope the rods won't want to exit the block prematurely. And it still being a 26 means the torque curve isn't gonna hike up all that much.   It didn't blow up on the dyno when they tuned it to 500ish crank. So I suppose it'll be okay for now. They did put a Tomei head gasket on first though which did not seal at all, and they redid it with a Cometic one. Which I hope won't be my water leak.   Mainly anything oil. So far all it has is the N1 pump, oil restrictor and a filter relocation kit with a cooler.
    • 15000? ish? Something like that anyway. It wasn;t so much a wear as a tear that then spread. Might have lasted a lot longer if not bothered by just one incident, whatever it was. I took a punt. They are really comfortable and do a good job of holding. My daughter HATED it when I first put them in, and probably still does now. She has sensory issues and hates the way they are all up your business. I'm 197cm and 95kg. Not fat or particularly wide, and the XL size seat is the rigth fit. If I was any fatter it would start to get too snug. Any skinnier and you'd possibly want the smaller width.
    • Mrs rs focus came factory with recaro cs  sportsters in it and they a pain in the ass to get in and out of with the really high bolsters, once you were in them they were one of the most comfortable seats I have ever sat in
    • The NA 2.5 has very little torque. You won't feel much. Those trannies are also a million years old now and it could well be f**ked. First generation electronically controlled autos will often refuse to kick down, ete, etc, depending on what's wrong with them.
    • Yes, but no but yes but no. Those "it's fine up to 500HP" rules and everything else like it were all determined back when the cars were 10 years old. As they are now 30 years old.....what do you reckon the chances of something shitting the bed are? I'd say they are much higher now than they used to be. You might be lucky. You might be unlucky. Spin the wheel and find out. Yeah, nah. It's actually exactly the opposite. Making boost early and having heaps of torque able to be generated right in the middle of the rev range will do more to damage an engine than having to rev it high to make the power. Think about the load on the conrods, bearings, etc, to make 400HP at 4000 rpm, vs 400 HP at 6500 rpm. So someone has already "let the Nissan out" which is how we describe the increased chance of a fiddled with engine to have had something done wrongly. Many more engines that have been opened die than stock ones do - even if you into consideration how they are treated wrt power levels and the like. Again, not saying that yours will definitely have been put back together by a moron. But the possibility does exist. It's still a lottery. Spin the wheel. What weakspots?
