  • Replies 70
Posted Images
my old r33 gtst ran low 13's consistantly with ;
Standard ecu + SAFC2
205 tyres on stock rims
turbo back exhaust (dump/front pipe custom made at Mettams mufflers in Morley, I thermal wrapped it)
standard air box (K&N element)
standard intercooler
10psi ( bleeder valve)
Pineapples (rear cradle bushes)
Light weight flywheel and upgraded clutch
With just these items I can get any decent nik R33 gtst into low 13's or with bigger tyres on the back straight into high 12's. Low 13's without spectacular 60ft times.
Notice the lack of Front mount intercooler.... Not needed to do this, get a good one when you upgrade the turbo and other kit.
That cars dyno after at the time of the low 13 was 175rwkw. It looked stock and was quiet and comfortable.
The JJR integrated split dump pipes are rubbish. They require machining to align the flange plate properly, the flange plates are sometimes not flat (warped).
Just get something from an exhasut place made. Without the split design. And then thermal wrap it.
Edited by rev210
https://www.sau.com.au/forums/topic/251396-heyy/page/4/#findComment-4358582
thanks for ur help rev210 do u knw any good places for dump pipe and so u think with 200 atw a 14 flat is posable
https://www.sau.com.au/forums/topic/251396-heyy/page/4/#findComment-4358607
My thoughts are that you need to sheild that pod filter. The pod filter if it has no cold air feed and heat shield, sucks in very hot engine bay air.
Or just get a factory airbox and cold air feed from someone throwing thiers away. Perhaps you can even offer to swap. Keeps the cops out of your face too when you pop the bonnet.
Mettams mufflers in Morely is where I have always gone for my cars. Pat there is a master and his quality work is very cheap indeed.
Mild steel dump pipe to the cat in 3 inch. Shouldn't be too much.
Go grab yourself some pineapples for the rear sub frame. they are only a tad over $100 and you can fit them in your driveway with 15min, a bit of effort and a crowbar. Easier if you have a mate to help out.
The clutch is something to save for if you only have a standard one in there as drag racing and the modest power increase will see it on it's way quickly.
When my car was dyno'd at 190rwhp I ran 13.8. It's pretty easy to do so.
The thing about dyno's is that they are really only a tuning tool. Making car comparisons is not what they are good for. :D
Edited by rev210
https://www.sau.com.au/forums/topic/251396-heyy/page/4/#findComment-4358629
Lorenzo, i think what you should do is race me for pink slips.. doo it, you know u want to :D
im takin mine to Wilkinson soon to get susp set up, good price and they sponsor some of the guys who drift at barbs.
needs to be done as i have ikeya formula lower control arms (which can either be set up for either drift or grip) rolls centers, whiteline sway bars etc etc..
Edited by Char
https://www.sau.com.au/forums/topic/251396-heyy/page/4/#findComment-4359588
:D:laugh::yes::cheers::banana::happy::mad::P:D :D
Blasphemy
Also if anyone wants some coilovers for their 32gtst my supplier has 1 set left at the price before the dollar dropped, shoot me a pm if anyone is interesed and ill give you prices and stuff but you will have to be really quick before it gets snapped up
https://www.sau.com.au/forums/topic/251396-heyy/page/4/#findComment-4359830
how much did u get quoted bro and u got no chance lol
https://www.sau.com.au/forums/topic/251396-heyy/page/4/#findComment-4359870
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
