A True Skyline Owner (at last)
  • Replies 40
Isn't it amazing you think that a compliance plate actually ment something but obviously the headlights weren't part of that, I wonder what else missed out.?
Note that my (HID) headlights we're converted to "Crappy " halogen to meet ADR compliance. That lasted about 10 mins when I got the car, The (HID) headlights come with the the car and nearly every euro car has them DUH. Well !! I do too now
Cheers MUZ
PS , My father has a 34 as well what fun we have. NIZR34GTT
Hi Shy33,
I am not quite sure who did the actual work but I got excellent service at BatteryPro (over near the Cemetary). The owner has a Z32 TT and they were certainly great people to deal with.
CYA34,
Does your old man have a red one? I think he and I have touched base a couple of times. Two R34's in one family, how utterly greedy is that? Good luck to both of you. Tell me more about the HID lights as I noticed the sparky only inserted a halogen bulb.
Cheers
Muz
NizR34GTT,
Yes I did. Is there something I should know? Being a little ole country boy we're pretty trusting up this way. I think I got a good deal minus the few little things already mentioned. Silver Snails huh! I've had my share of red cars. Something about them, at least the ones I owned. People just kept running into them. At least with black, they can now actually claim not to have seen me.
Does your R34 suffer from this stalling problem? If so what mods do you have as I'm looking for a commonality with mods to point in the direction of a solution.
Cheers
Muz
Hi Muz no problems with Advance Autos I got mine of them about 12 months ago absolutely over ther moon with it .They were very good to deal with and honest so what more can we ask for.
I don't have any stalling problems with mine.
I have a blitz cooler ,turbo smart boost cotroler,3" stainless system few other small bits and pieces.
Have you got a blow off valve ?sometimes if they are not adjusted correctly you can suffer idling problems.
My personal mechanic (SON) put a new set of iridium plugs in it the other day so might pay you to look at them to.
Probably better speaking to CYA34 he nows them inside out so he might be able to help you.
Ray tol;d me from Advance yours had a lot of nice goodies on it,it was still in the showroom covered up when I went over to see him the other day.
Give cya a PM and see if he can give you some clues.
Regards Rod
Thanks for the heads up on the stall problem. Yes I dealt with Barry and Colleen and they were absolutely great. Not often you can say that about car sales people but it's true. Did all my deal by email except for a very quick test drive between flights. If I can just cure this stalling problem then I will be totally content. I'll PM CYA34.
Stay in touch.
Cheers
Muz
Hi Muz. If you have an externally venting Blow Off Valve, you can most certainly blame that on your stalling problem. A lot of people opt for changing over to a nice loud BOV and find that the car begins to run rich and stall frequently. They then end up putting the factory BOV back on.
To solve the problem you can purchase idle stabilisers and the like, but if I were you I'd purchase an internally venting BOV like the factory or swapping someone with a factory one.
G'day NIZR34GTT,
The BOV is a Turbosmart Plumb Back arrangement.
Being a newbie to the Skyline scene (Truly Great Cars) and a first timer on turbo cars, this is all a very new experience for me. I'm loving it so far. I have always been a car nut and this car has really suprised me. My wife has a BA Falcon (a nice Aussie car) but it's not a patch on a chassis that is 4-5 years older. Just shows how far behind we really are in terms of vehicle dynamics.
I'm starting to have a bit of a play around to see what makes it purr. Took the plastic cover off the engine today after work and found a small black hose not connected to where it should be. Reconnected that but doesn't seem to have made any difference. Like I said in an earlier post, these imported pre-owned cars are like opening boxes of presents ....... full of great suprises.
I have a few small issues that I'm thinking about going back to Advance about but they really are only small issues so will give it some thought. Other than no headlights on one side, the two trip meters don't appear to function. This car has a full set of Nismo gauges (absolutely brilliant at night) so I'm wondering when the instruments were changed whether they were not connected properly or something.
The stalling issue is the biggest worry as it has the potential to be something that could very well cause an accident. If your son can give any guidance on that, I would be extremely appreciative. I'm considering swapping out the Microtech computer and fitting an Apexi Power FC but will wait and see if I acn get this stalling problem fixed first before I start down the "throw buckets of money at it" path.
Cheers for now
Muz
I am like you I turn the key and away she goes if there is a problem, Help CYA3
I have been about vehicles all my life but these are to technical for me so thats why I my son a yell.
I am from the old carby days lol.
I did't get your PM as i had changed my email but that has been sorted now so should be ok.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
