Dating Blocks By Engine Number
webber
 Share
OK guys, basically the way this will work is:
I need your co-operation on the following:
Please state: Model, year & month (if not the first4 digits of your vin) & the first 3 digits of your engine number.
I.E. R33, Nov 95, (or alternatively ECR33-0633xx) & RB25-145xxx (could even specify S1.5)
from this information we can then compile a list to give approximations of what date an engine might be.
I.E. the RB26 list so far looks like the following:
R32 1994 45xxx
R33 1995 March 51xxx
R33 1995 May 55xxx
R33 1997 Feb 63xxx
Please only post if your car has the original eninge fitted thanks
cheers
RB26 List
R32 1994 July 42xxx
R32 1994 45xxx
R33 1995 May 55xxx
R33 1997 Feb 63xx
RB25 List
R33 1995 Jan RB25-116xxx
R33 1995 Nov RB25-145xxx (S1.5 - Later coil packs)
RB20 List
Keep them coming guys, Hey cartman, sorry i couldn't use your information, if you don't know what month/year, i can look it up through nissan fast, from the full or partial vin number cheers...
RB26 List
R32 1994 July 42xxx
R32 1994 45xxx
R33 1995 May 55xxx
R33 1997 Feb 63xx
RB25 List
RB20 List
Mines doesn't have a number just RB26, I have been told thats beacuse it was bought new from nissan. Its 2.7 by HKS in japan.
will pm them thru to you sometime tomorrow!
Cool guys, i am actually going out shortly to check some of my other skylines and get there details, once i have those i will report back. that would be top work cartman. Cheers...
RB20 & RB25 numbers will most likely be all over the show as they were used in other model cars. But we may be able to get somewhere with it.
just checked some more of my liners
R33 1993 Aug RB25-59xxx
R33 1993 Aug RB25-63xxx
R34 2000 Sep RB25-375xxx (S2 Neo)
RB25 List
R33 1995 Jan RB25-116xxx (S2 coil packs & AFM)
R33 1995 Nov RB25-145xxx (S2 coil packs & AFM)
This will be handy as i have a heap of engines, that hopefully soon i can work out what date etc they are
  • 1 month later...
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
