Hi guys,
I have a 95 R33 gtst which currently has a fmic, turbosmart boost controller, bov, zorst.
as you can tell it's nothing to serious and is fairly standard. I am wanting to upgrade and was just wondering where you think I should start first? ie) turbo, ecu, injectors etc??
any advice would be appreciated,
Thanks,
Sam
https://www.sau.com.au/forums/topic/251427-what-next/
Hey mate,
Good basis you have here.
First thing I would do is take the car to a mechanic and have a compression and leak down test done to assure the strengh of the engine (So it doesnt break if you make more power).
RB25's are strong and stock internals can see 250ish KW all day and it should be fine with the supporting mods.
I would get a Z32 AFM, say a Greddy GT-RS turbo, Power FC (If you can find one) 550/700cc injectors, If that boost controller is a bleed valve id get an electronic one, then a nice safe tune assuming the report came back fine from the tests. That would see an easy 250rwkw and that would be fine for you for the time being. If you want to go further, more boost ect that setup could push around 280-300 but I wouldnt.
https://www.sau.com.au/forums/topic/251427-what-next/#findComment-4352375
Hey mate,
Thanks mate,
It is a bleed valve which I know arn't the best and I will be def getting an eba. I'm getting abit of boost spike due to the bleed valve which is really annoying..as for everything that sounds good, I will get a compression test done. It's also just ticked over the 100k so need to get it a 100k service also.
yeah 250kw would be a very nice jump (untill i get bored of that and want to go faster :laugh: )
cheers for the advice mate much appreciated.
https://www.sau.com.au/forums/topic/251427-what-next/#findComment-4352389
Yes getting the engine checked over for its health before doing anything is always the best move, you dont want to break the motor because you didnt replace a $150 part that would of been detected if you got the tests done.
250KW will beat every stock holden and ford on the road, it will be fun on the track as well.
Make sure you get a oil cooler if you plan on doing any track days or if you plan on giving the car a hard time. One can be had for around $300 i think. It will impove oil cooling very well.
All the mods ive listed would be doing it the "right" way. You could always get a high flow rb25 turbo, 550cc inj, z32, a wolf 3d or some cheaper ecu, and run 18psi.
Or do it right with good parts. Buy good brands stay away from cheap crap, you wont regret it. Just i hope you dont plan on selling the car soon because mods dont really hold their value.
https://www.sau.com.au/forums/topic/251427-what-next/#findComment-4352420
I've had the car since Aug 08 and plan on keeping it for at least a few years.
I know what you mean about people modding their car cheaply and then end up running into all sorts of problems :laugh: and spending thousands and thousands for the same result as if it were done properly.
I'm also confident the gear box needs a reco as I'm getting a rattling sound in the gears up untill around 2000pm then it's ok. I think the bearings and or seals are shot. I have been quoted $1200 by 1 place in Syd for a reco or $2500 for a full GTR gearbox install inc. Think for now I'd go the reco as it's alot of money and I would rather spend that on other mods.
cheers mate,
https://www.sau.com.au/forums/topic/251427-what-next/#findComment-4352468
I like the way you think, My car was a perfect example. I modded it with expensive parts and known brands, Greddy, HKS and Apexi. My mate who had the same car at the time done cheaper mods (Just Jap FMIC $300 ect) and i ended up with 32 more KW's @ the wheels over him and he had a newer engine with better compression.
My cylinders was 154 accross all 6. 148-155 is good
https://www.sau.com.au/forums/topic/251427-what-next/#findComment-4352716
firstly how much do you wanna spend?
whats the car for?
ecu is def the next step for you, as well as some suspension work. pfc is the obvious option.
there's no point having all that power on a stock suspension setup IMHO
i'd rather have a highflow with stock injectors and afm @ 230 rwkw with a full house suspension setup than 250 with stock suspension
just food for thought :(
my journey went like this... (in rough order)
car - 33 gtst (came with with FMIC, clutch and lowered springs, short shifter)
wheels
full service and checkup
pod in box with CAI
slotted rotors DBA 296mm & good pads
PFC
splitfire coilpack (were broken so had to)
new plugs BCPR7ES gapped @ 0.8
tune
coilovers
strut brace
swaybars front and rear
castor bushes
camber bushes
pineapple bushes
hicas lock bar
cosmetic mods
audio visual mods
EBC
fuel pump
injectors
z32 afm
adj ex cam gear
new turbo
tune
prolly forgot stuff but get the general flow
https://www.sau.com.au/forums/topic/251427-what-next/#findComment-4353216
whats the car for?
wheels
pod in box with CAI
PFC
tune
coilovers
strut brace
castor bushes
camber bushes
pineapple bushes
hicas lock bar
cosmetic mods
audio visual mods
EBC
fuel pump
injectors
z32 afm
adj ex cam gear
new turbo
tune
the car is my daily but i'd also like to take it to the track (not turn it into a track car) and the occasional drag. So basically just a daily street car.
I don't neccesarily have a specific budget as I will obviously be out laying money over a period of time but i'm not too fussed as I have a mate in NZ thats put more than 40k into his rb30 s14 so I know it's costly lol.
first things first I need to fix the gear box then get it a major service.
since i will be doing to modding in small parts, just wondering after the service and gear box reco what I should do? I'm thinkin pod, afm, pfc?
https://www.sau.com.au/forums/topic/251427-what-next/#findComment-4353265
