So it lost ~36kW over the manual. What's that, nearly 50hp? That sounds about right to me but what auto/converter is in it?
Like 2rismo asked,,,,did it have a std converter in it? And would a higher stall converter make it read a lower overall rwkw?
  • Replies 50
Posted Images
when i got my trans built with high stall i also installed poncams , then re dynoed it and i lost 40 rwkws over standard torque convertor and standard cams, nothing else changed.
Mike at MV said the high stalls do suck power when run on a dyno, and if i wanted to be a dyno hero i should stick with the stock convertor as it will allways read a higher no.
but in a straight line the high stall will allways out perform the stocker.
Edited by dangerman4
Yeah i have found this too, going to a 2800 rpm converter dropped my mph from 118 to 113 ! , but ET dropped from mid 13's to 12.3 !
i now have a 3500 converter but yet to run strip.
I only show 250 rwkw's and can't seem to get past it..... however my 550cc nismos are maxxed at 6000 rpm, so this gives me more of an indication of where i am at relative to others on here. (740's arrive tomorrow!)
URAS, have you ever noticed on the R33 auto's, if you ramp them too slowly you get a big power dip just at the start of the run ??
The LINK i run has a rpm setting for cam on and cam off. I did notice if i turn it on to early it is noticibly harder to cruise up small hills, more throttle required, so i raised it to counter that, but the switch off has always been 6000, and i am ashamed to admit i haven't played with it yet when on dyno... will do now though as last run late last year i started noticing the top end dips !
Im chasing a problem of not being able to break thru 250rwkws. New larger turbo yeilded 250 same as previous, dropped exhaust BP from 7 to 3.2 (collapsed cat), nothing...250rwks....... its frustrating.
I often wondered if the auto comp was playing silly buggers....
Dyno opens again next week, so i'll be back on soon to try new options (HKS cast mani and replace turbine housing with proper .63 turbonetics, rather than bored out VG30 one. And Ext gate + full 4" inlet to 4" pod (yet to be shielded, but just going for best soloution on dyno with bonnet up for now, until problem/restriction is found then will box properly for cold air.).
Thanks for the info though, i really appreciate these posts where you guys show real data and measurements in your posts, great resource.
Gary
Edited by Fastrotor
Gary whats your fuel pump?
im also running 550 nismo's and im still below 90%
your fuel pressure must be very low to be maxing them at that power range.
i had a similar turbo and i got it to 270 but that was about the end of the vg30 housing.
im running a 044 intank with a FPR set at 43 psi base pressure.
Oh i forgot to mention that in that spiel , thanks Darren.
Yes i now know pressure is a problem, i too run an 044 pump i bought off of "Pump Daddy" off the forums here, however i suspect its faulty.
The last dyno run i did last year when we discovered the new turbo and auto didn't add a kw extra, i had put a FP gague on and sure enough the FP topped out at 55psi on a 40 psi base, when running 20psi. So effectively have 35psi across injectors to your 43. which reduces there effective size to 496cc, plus it was running very rich, so that probably explains it..
When i got home, the pump was noisy as hell.... due to heat i assume , hasnt done it since.
I have a new walbro sitting here waiting for me to get around to throwing it in. Plus i have to sort out a dual volt setup that allows full volts when 'full on' , for guilt-toy.
I figured 550's should have been enough based on your results previously, and a few other guys around the 300 mark, however since i have sold my 550's (guys still isn't ready for them so i'm still running them) ,i figured i may as well buy some 740's.
I'll get the pump in this weekend, as with the 740's and should be on dyno next week.
I suspected the VG30 was out of puff, even with all the meat taken out of it, and hence why i went to a full turbonetics .63 housing.(and HKS cast mani) Time will tell i guess. I've got the option to go to the .8 later if this still isnt enough, however i sprint race the car mainly so i dont want to kill off bottom/mid any more as its already crap (full noise/boost at high 4000's)..
Gary
Edited by Fastrotor
So for us people with standard cams and a slightly bigger turbo what rpm should we hace it set to??
i cant give a blanket answer as every setup is differrent, some need it dropped a few hundred some need it raised alot.
Interesting... was it the exact same car? Or just two cars of similar spec?
Has the auto box been touched at all bar the shift kit?
That's a 12.5% loss in your test; so an accurate 'window' would be between 10-15%? Wow... bringing that max % into my numbers, my car would have 450rwkw now if it was manual as opposed to 380rwkw? Mmmm, I think not.
Nissan from memory quote a 8kw or 9kw loss factory auto vs manual
So indeed, sound pretty right on :D
think kw loss not percentage as your car uses the same box.
So indeed, sound pretty right on :P
I'm pretty sure Nissan's quoted kW figures are at the flywheel (187 vs. 184 for example) and as such, reflect different states of tune rather than different drivelines.
If you've seen another spec I'm unaware of then apologies in advance.
So as a realistic figure - what would be a ballpark on a manual version of my car now considering 380rwkw in the auto?
And Trent, could you please elaborate on your last reply to me - I kinda get it, but not really :( Are you saying that there is no magical %, it's purely a number?
Stan, think about it like this:
You have a 100hp engine that makes 65hp at the wheels. That's 35% loss, yes?
Then you whack some gas on it and it now makes 150hp at the engine. Would you expect the wheel hp to be 97.5hp (35% loss) or more like 115hp (the same actual hp loss as the original scenario)?
Assuming the same driveline (flywheel/flexplate, clutch/converter, gearbox, tailshaft, diff, driveshafts/axles), why should there be significantly more (nearly 12% extra) drivetrain loss just because you upped the engine hp?
Sure there might be more heat/noise created (in the drivetrain) but sticking to an arbitrary and uniform drivetrain loss percentage or amount is ridiculous. Even so, I've heard some otherwise very switched on people suggest it as fact.
Maybe it was a HR31 difference... bit vauge in my brain...
But would it be a state of tune or are they accounting for the loss?
Interesting as im not sure!
410-415rwkw is realistic.
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
