  • Replies 145
Originally posted by Dr_Drift
Leewah - Where's this dyno comp?? may bring endless??
The dyno comp is around the corner from Ice Performance. Can't remember the name of the place but they got their dyno installed a few months ago.
It's got one of those 3 letter names but it's not TGS or BMT :(
If you give Gerald or Nige a call, they could probably tell ya.
Originally posted by Oyabun Leewah ... GTR 34 is a top guy .. should be a great day at Heathcote ..
So I hear. That's why I wanna meet them, father and son.
And to all those thinking this is gonna be a showdown of sorts between the LeewahGTR and Endless, please reconsider. Let's take all the factors into consideration before even thinking that this would even be a half decent comparison.
LeewahGTR:
R33 GTR which means 4WD.
Running Nittos.
2 years of R&D and track testing.
Best time 10.47@137MPH
Endless:
R32 GTS-T with newish RB26DETT rebuild
RWD!!
Currently running slicks
Less than max boost
Best time 12.7 @ 121
Been on the strip once and broke the axle
As far as I'm concerned, Endless is still in its early development stages and has nothing to prove to anyone. The same goes for LeewahGTR. I'm doing my own thing and BMT is doing their own thing. If we end up lining up together, so be it and let's have fun racing, but let's not build this up to be like a Munro Kier race coz it's not!!
I'll see some of you at Heathcote whether LeewahGTR makes it up there or not.
Originally posted by R31Nismoid
a translation for those not quite so resourceful  ???
All you need is google mate :)
http://www.google.com.au/search?q=Oyabun&i...le+Search&meta=
and scroll down a bit the answers are there!
Or if you want to be more thorough -
http://www.google.co.jp/search?q=Oyabun&ie...UTF-8&hl=ja&lr=
then scroll down again :P
    • The previous switchover point was 501mv. The stock value is like ~360. They now were idling at about ~880. The thing is, most people get a false lean condition. I am getting false rich conditions. This isn't a quirk of terminology, most cam upgraders get awful fuel economy because the O2's read false lean and add fuel - Mine are attempting to aggressively subtract fuel.
    • So... the whole idea was to upgrade the power of the motor from stock. The motor I bought with the gearbox had 'some' stuff done to it in the past, but it wasn't as well thought out/what I had wanted to do. The stock heads typically are a big restriction on LS's and need porting to unlock quite a lot of power. You can then go a bit silly with aftermarket castings to get more, aftermarket intake manifolds for a little more, and then porting those for more. <- We are here. Nobody in Australia really goes down this path (for some reason). It might* make 3kw or something more than doing things the tried and true path for 10X the cost. So that's probably why - I wouldn't even recommend it to people, the money was and is likely better spent on just CNC'ing the stock heads and putting a 6.3L stroker kit in. I didn't want to go down the 'normal' path and then think: But if I'd just done a bit more - I could have had a slightly better result. I assumed the heads were running out of flow and it always annoyed me - Turns out the previous installer advanced the cam 6 degrees so this is likely why it was coming on earlier and running out of puff earlier than advertised. The body panels were just lack of planning/no information on this anywhere on the internet and the fact they came out different was annoying. From test fitting the guard it appears I could have gotten away with GTR guards only, but I got the bonnet and raisers and everything else as well for a pretty decent package deal.
    • So you had a car that by all accounts drove well and survived track days, and that was looking great after months of being stuck at a paint shop. Some might call that a finished project. But you decided this is not quite right. So now the car does not run anymore. And the engine doesn't fit anymore. And the body parts don't match anymore. But, this is progress somehow. Greg, I think your subconscious does not like you and does not want you to drive this car. (I know I know, this whole escalation was not intended, but man, what a rollercoaster)
    • Yeah, but the narrowband is truly narrowband. So you take it out of the linear zone and it is effectively nonsense. And that linear zone is so literally narrow, that nonsense is not very far away. Unless they are flicking back and forth across the stoich point, for real, under actual control, they can't be trusted for anything except entertainment value.
