Hey guys,
Excuse me for being a noob-ass idiot but yeah i need some help.
I recently bought an 1994 R33 and just found out that my cigarette lighter does not power any sort of charger that I put in.
It looks kinda flimsy at the moment and its obviously not working so...
Does anyone know how to re-wire a cigarette lighter thingy?
or
Am I screwed for buying a phone charger?
Thanks a lot,
=Dhiv=
is it the fuse?
My lighter's stuffed as well and won't light the lighter let alone charge anything and the fuse is gone I've been told it's pretty cheap to fix, ring around some auto sparkies in your area see who can fix it for you, may only have to pay for the fuse
Edited by MeLSki
cigarette lighter has its own fuse, located to the right under steering wheel in the fuse box thing.. 4th from the bottom on the right hand side - 15A fuse. You can buy them at most servos for like $2, i've bought some from Shell before.
fusebox diagram
Dude, if he can't figure out if it's the lighter or the charger then I highly suggest going to an auto sparky before playing with wires himself... :)
Edited by MeLSki
lol my cig lighter wasnt working but i blew the lil bit of dust/dirt etc off the fuse area, then made sure the fuses were securely in which they were, went back in the car and bang its working. always a logical reason why things stuff up.. just try the easy ones first cos u never kno! then see a sparky. Mind u if u see someone genuine and the problem is simple they shouldnt charge u much at all! and if u do find a genuine person maybe by a lotto ticket on ur way home lol :)
Edited by 1R34SON
Lol thanks guys - Doesn't look like the fuse but yeah i think its the actual wiring cos the thing is coming out when i pull out the actual lighter thingo
The casing isnt even sittin straight
so yeah ill go have a look
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
    • SO whats the deal with this issue? I've read a heap of posts from the infinity owners in the US having full engine swaps done under warranty. Most claims are done on earlier cars than 2019 but I'm sure I've come across claims of 2020 models also having this issue. I like the 400r and Q50Red/S but can't fathom dumping close to 50k on a car with terminal issues!!!
    • The above video is working normally. That is, that's how the right hand indicator should cancel when rotating the wheel left.
    • I noticed that I could see creatures on the moon when I turned my new headlights on. I thought I should check the alignment. It's pretty rudimentary but I just grabbed some dry wall and put it against my tablet and made sure the beam was below the height on the headlights. Ie the beam is at 600mm on my car, I just made it lower than that 7.5m away.  Not the best but it'll do until I can do it properly at the local shops.
    • As @Duncan said - the bores are most likely to cop it. But anything can and does happen. Rods are cheap. Rods are good. The work to rebuild the motor will be 30x the price of rods. You won't notice it.
