Make: Mitsubishi
Model: Cordia
Milage: 140xxx
Transmission: Manual
Colour: Red
RWC supplied? Out of rego, but can organise pink slip
Currently registered? nope
Price: 5k, no offers.
Contact: George Via PM
Comments / Modifications:
~~~NSW Fully Engineered~~~
1985 AB
Single cam 4g63
Fully rebuilt (about 8000kms done)
balance shafts removed
ACL race bearings - only done 2k ks
balanced/blueprinted
Custom billet cam shaft
Adjustable vernier cam gear
Custom 60thou forged wiseco pistons
Ported/polished head
ARP head studs
ACL head gasket
EMS Dualsport ecu with hand controller (Just had computer upgraded for laptop access too) mouted in dash
M&W direct fire ignition
heavy duty leads
Sard 600cc injectors
Sard fuel pressure regulator
Custom fuel rail
Bosch 044 fuel pump
Hyundai intake manifold
XF throttle body
custom polished intercooler piping
PWR silicon hose joiners
HKS air filter
Custom made front mount intercooler
Blitz KKK 3070 550HP turbo
External wastegate
Screamer pipe
Turbotech boost controller
Blow off valve
Custom made exhaust manifold and dump pipe
3" mandrel bent exhaust turbo-back with cannon style muffler
Custom PWR radiator
Custom made Heavy duty Jim Berry clutch
Genuine speedflow braided fittings throughout
oil catch can and breather from intake pipe
Custom made strut brace
Lowered on pedders springs
17x7" white wheels
new wheel bearings
VR4 rear brake upgrade (disks all round)
paint and body is pretty much perfect
Interior is very very good
White dials
3 x Autometer gauges mounted wher centre air vents are on custom laser cut metal panel
SAAS steering wheel
turbo timer
Recaro passenger seat from evo
Pioneer cd/mp3 player
6" round pioneer speakers mounted in doors
6 x 9" pioneer speakers in parcel shelf
Dark tinted windows
Images:
More pics can be sent to genuinely interested people. Selling as I need the space.
Genuine inspections are welcome.
Cheers
https://www.sau.com.au/forums/topic/251521-fs-mitsubishi-cordia-gsr/
swap??
Item: AE92 1992 COROLLA SE
Website: N/A
Item Condition: GOOD
Reason for Selling: OVER IT
Price and Payment Conditions: $4000 OR SWAP
Extra Info:
AE92 Corolla SE
MODS-
Brand new excedy clutch
Cat back exhuast with dump tip
18inch hp shadow chrome rims with 80% tread
King springs
Dvd player with bluetooth, ipod jack, memory card reader
10inch sub
800w amp
JVC 6x9s 4way
Kicker Front tweeters
7months rego NSW
Momo race steering wheel
Sports pedals
SX Hatch/boot plus wing
No oil leaks or blows smoke
Just serviced
New brake pads
Central locking
Tinted windows
GTi front grille
Front strut brace
price - $4000 or swap
located in liverpool area.
pics-
http://www.boostcruising.com/forums/index....t&id=633911
Pictures: ATTACHED
Contact Details: 0403710821 OR PM MSN - [email protected]
sorry, not interested in trades. Have too many cars taking up too much space as it is.
This car has had ALOT of money spent on it. Bought it with intent to make 300Hp atw, but haven't bothered getting it tuned for such, as I almost never drive it any more.
Thanks.
  • 3 weeks later...
  • 3 months later...
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
