Hey all,
time for another whacky 25GTT question thread....
this time its about the amazing world of RAM.
OK so this is my system:
My setup?
Case:Coolermaster Centurion 5
Motherboard: Gigabyte EP35-DS3
CPU & CPU Cooler: E8400 clocked just a bit to 3.3 ghz running a xigmatek cooler and managed by a schweeet zalman LCD fan and PSU controller, very blingy but lets me control everything!
RAM: 4gb 800mhz ram (kingston i think), do you think its worth going the 1066mhz or not worth it??
Monitor: 22 asus splendid monitor
Graphics Card:Ge force galaxy 9800GTX 512MB (might need to go a 4870 soon?)
HDD(s):2 yummy 500GB HDD's running in raid format so 1TB in total (600GB still left to go)
Recently i have seen 4GB worth of Kingston Hyper 1066 mhz RAM for $90 shown below:
http://www.ple.com.au/?p=snapshot&inventory_id=37851
So my question is for performance is there an advantage in going the 1066mhz? the guy at PLE said go for a more high performance 800mhz RAM for future clocking at the moment my cpu is clocked from 3ghz to 3.3 i doubt i will ever take higher than 3.6 ghz on the E8400 chip. so would the kingstone RAM be suffice? i thought the 1066mhz would be better but the guy at the shop said the 800mhz offers less latency so better for gaming?
There also is this kit which is pretty high end for RAM:
http://www.ple.com.au/?p=snapshot&inventory_id=33701
what would you recommend? is there a huge difference in me getting 1066mhz?
Also currently i have 4 x 1gb sticks, is there a performance increase in going 2 x 2 GB sticks?
So many questions such little time :-)
Thanks all!
Edited by 25GTT
https://www.sau.com.au/forums/topic/251536-1066mhz-ram-vs-800mhz-ram/
only real advantage is if you're going to overclock hard with the ram @ 1:1 ratio :P
for 3.2ghz 800 is perfectly fine, even probably closer to 3.8ghz @ 1:1
much more and you need the 1066 for the extra headroom for easy clocks (like i have @ 4.3) as the timings are much more friendly... but you can make 1066 ram run @ the 800 timings... so the dude in the shop is a bit wrong there IMO.
Better off with 2x2 sticks
End of the day, you wont really notice a difference gaming or otherwise for the general user with 800 or 1066. The differences are that small it doesnt matter
The timings on that Kingston Hyper X are somewhat loose (1066mhz @ 7-7-7-20)…it would be more ideal to spend a little extra (but not Corsair extra) to have CL5 timings (ie. 5-5-5-15 / 18) at that frequency.
Given that you don't intend to O/C much over 3.6ghz (400x9), then 800mhz (or 1066 @ 800mhz) preferably with CL4 timings would be perfect. As long as your current memory is stable, there won’t be a big performance difference going from 4 to 2 new sticks, except slightly less stress on the memory controller and lower voltage drawn with the 2 sticks.
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
    • I hear the old "I'd never use a pressure washer on my motorbike" BS in the dirtbike community too.  The only people that have had a problem from using a pressure washer on anything are the people that aren't using them properly.  If you hold the wand any more than 45 cms away from pretty much anything (radiators, wiring connectors, paint, etc) you aren't going to cause any damage.  We've had detailers wreck moulds and seals on cars at work before and the only reason why is they held the pressure washer too close and on the one spot for too long.  If you have 5% more brain power than a detailer then you know not to not do that and you'll never have a problem.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
