The hicas light stays on occasionally, after i start the car. If I turn the car off and on again, it goes away.
It's happened maybe 6 times now, in the last 3 weeks.
It never comes on after start up, while driving.
When its on, theres no issue with steering etc. Car drives normally. So i'm guessing some sort of wiring fault with the light, or a switch?
Any tips or known issues to look for here?
The power steering fluid was on the low mark when i checked, so i topped it up, but that wasnt it.
My hicas is intact, and i have no issue with it. So the lock bar suggestion isnt what i'm looking for.
cheers
Edited by Munkyb0y
https://www.sau.com.au/forums/topic/251550-hicas-light-r33/
  • 5 weeks later...
ive tried getting into hicas diag mode. no luck.
can someone spell out the procedure for me?
this is what i tried.
start engine
turn wheel left then right 20deg 5 times (i tried 6 times too)
press brake pedal 5 times (tried 6 times too)
then i read somewhere, a faulty steering posiition sensor will prevent entering diag mode
if i have the procedure correct, i need some info on the steering position sensor. ie. how to get to it, and remove/replace, or test.
if i have the procedure wrong, slap me, and show me the way
cheers
https://www.sau.com.au/forums/topic/251550-hicas-light-r33/#findComment-4411494
the day i removed my hicas was NOT a day i look back fondly upon!
make sure you have a good couple of hours... its kinda tricky to get happening the first time
Dont listen to him :) It is a simple job and if your on a hoist will take about 40-50 mins max. And i even had to drop the rear muffler to get at one side.
Use the guide on SAU and its a piece of piss. Even easier if you have a mate helping.
https://www.sau.com.au/forums/topic/251550-hicas-light-r33/#findComment-4412820
I had this same problem, I ended up ditching hicas but before I did I found that just disconnecting, cleaning and replugging in ALL the wiring plugs to do with steering and hicas stopped it from happening. I couldnt trace it to just one connection.
https://www.sau.com.au/forums/topic/251550-hicas-light-r33/#findComment-4412823
i've read conflicting reports on r33 lockbar installs.
what i want to know is....
does it affect the progressive power steering? i.e. does your steering still remain lighter at low speeds, firmer at higher speeds?
or is that lost, and you get heavier steering all time when you fit a lockbar
edit: is the steering position sensor used for anything besides hicas? does it need to work?
Edited by Munkyb0y
https://www.sau.com.au/forums/topic/251550-hicas-light-r33/#findComment-4412954
so far i havnt even noticed a difference in the steering with the lockbar.
No noticeable change in heavyness at low speeds etc etc so couldnt comment. Im taking it to the track on tuesday. 1st trackday without it so ill let you know if it was much different to with it in.
Daily driving tho.. hasnt seemed to effect much
https://www.sau.com.au/forums/topic/251550-hicas-light-r33/#findComment-4414095
Yup yup. Leave the computer where it is and just remove the globe.
The track (just got home) was amazing.
I wish id put the lock bar in sooner. Coming out of corners a bit quick and having the ass step out is so much more controllable! I was just stomping on it in 3rd and "power sliding" haha. With the Hicas i was getting thrown all over the place.
I got a couple of vids of some minor skids ill link when theyre uploaded. But the best ones were at the end of the track that there was nowhere to video from :huh:
So, go DO IT DO IT!!
https://www.sau.com.au/forums/topic/251550-hicas-light-r33/#findComment-4419946
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
    • Maybe you should do some more reading.  Google positive effects of ADHD and you'll get your answers.  One of my personal downsides of ADHD has been talking before I think.   Maybe you have it too?
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
