Tons Of Parts For R34 Gtr, Most Are New, Hks 2530s, Greddy Drag Cooler, Radiator, 19" Ce28n, Arc Exhaust, Nismo Front Bar + More
Had big plans for my car but circumstances have changed so i'll have to offload. All parts are brand new in original boxes, unless stated otherwise. Most of this stuff was purchased when the yen was shit as well. Can be picked up from Hornsby, Syd. or can be posted to you at your expense. Pm me or leave msg here for pics or more info.
Also, I may have other parts as well not listed. They're just not here yet so if you're after anything, dont be afraid to ask.
HKS 2530 turbo kit - $4000
Trust/Greddy Spec R HG, Type23 Intercooler. This is the thickest cooler Trust makes - $2400
Trust/Greddy hard pipe kit for cooler - $750
Trust/Greddy complete intake kit including Airinx filters, z23 afms, and all piping from filter to turbos to cooler pipe - $1700
Trust/Greddy aluminium radiator - $1100
Trust/Greddy aluminium radiator pipe - $150
Tomei Expreme exhaust manifold - $950
Volk CE28N in 19 x 10.5+12 - bronze, rims only - $3900
Volk GT30 in 19 x 10.5 +17 - Formula Silver, rims only - $4400
Kumho KU31 275/30R19 x 4 tyres for above rims - $1100
Volk RE30 in 18 x 10.5 +18 - bronze, USED and only 3 rims. 2 are perfect, 1 has very slight guttering - $1600
Nismo front bar in Bayside Blue, USED but in excellent condition - $1800
Trust/Greddy clear timing belt cover - $100
Trust/Greddy oil pan kit - $600
HKS SSQV kit including aluminium pipe - $650
Sard fuel rail - $390
Works Bell Short Boss Kit for Rapfix (60mm) - $250
ARC Titan cat-back titanium exhaust, USED but as new condition, only done very very low kms - $2500
Edited by mxfly
Pics of the 2530s and cooler. The cooler is 115mm thick. One turbo is illustrated, the other still in the box.
Hey mate..
Any more details on this item?
Is it the trust sump extension with baffles?
Cheers
Hey mate..
Cheers
I'll check tonight for you.
Meanwhile, these items are on hold pending payment.
- RE30 18x10.5, set of 3 rims
- Greddy timing cover
- CE28N 19x10.5 set
- Greddy intake kit, minus afm's
its not the thickest intercooler Trust makes....mines 160mm thick!
picks of the works bell boss kit pls
Edited by DiRTgarage
Yep I got it wrong it's the 115mm one. I couldnt edit the first post.
Yours is the super hard core one! lol
eugene id like to inspect the titanium cat back if possible.
Thanks Milhouse..
Hey Milhouse,
For sure mate, anytime. Just call me on 0421 141 538.
cheers Euge
haha what the hell was I thinking when I wrote millhouse!!
Its Milhouse from autosport mate.
Ill be in touch during the week thanks
Update on parts that are SOLD:
- CE28N in 19"
- RE30 in 18"
- Trust clear timing cover
- Trust sump
Parts that are on hold pending payment:
- HKS 2530 turbines
- Trust cooler
Parts back up on sale due to no response from buyer:
- Trust intake pipe kit
Update on parts that are definitely SOLD:
- HKS 2530 turbine kit
- Trust Spec R intercooler
Parts that are on HOLD:
- Trust radiator
pics of the front bumper. negotiable on price at all?
Sry i'll take pics of it tomorrow. All prices are firm atm. A new Nismo front bar these days would cost serious dollars.
    • I have seen a case where the starter motor shorting against the casing caused a massive voltage drop + so much EMI that it caused all the sensors to spew garbage data at the ECU. Test the battery to make sure it has acceptable CCA/capacity first, I have gotten "brand new" batteries before that couldn't even power a 10W light bulb without dying probably because it sat in a warehouse too long without being charged. Only easy way to diagnose this 100% is put an oscilloscope on the battery and also look at key sensors to see if there's any clues.
    • There's a bunch of smaller shops that don't quite attract Singer money but are still hiring from that same pool of labor. Those are the body shops that you go to when you can't afford a Singer, but your old Porsche needs some serious bodywork. You can't exactly take those cars to the usual insurance body shops. When I say restomod, I mean they'll do something other than 100% OEM/OEM-equivalent aftermarket parts R&R. In the Porsche world this would be stuff like taking a 50k 964, doing a bunch of deferred maintenance/unwinding the nightmares the previous owners did to the car because a lot of people that own these cars tended to be penny wise, pound foolish types, then maybe some relatively simple off the shelf modifications to things like suspension, transmission, engine, headlights, etc. and you've spent 130k USD. When even the worst houses in the poor neighborhoods are worth 1M USD and the nice houses in wealthy neighborhoods are worth 3-10M USD suddenly 130k spent on a 50k car seems cheap.
    • Hoping to get a few ideas to help troubleshoot this issue, I'll try to keep it short.  A mate popped the motor in his 2018 LDV T60 with the 2.8 turbo diesel motor. He swapped it and I was his phone a friend when he got stuck.  The new motor is in, however it won't fire. The battery is literally brand new, when you crank it the volts very quickly (say 2 seconds of cranking) drop to 8 volts and the engine stops turning over. Watching the belts, I'd say they move about 5cm before coming to a stop. We put a booster pack on, no change.  The only potential issue I'm aware of is, when we pulled the motor the grounding strap was still attached. The strap copped a thrashing before we realised what was going on. It looks okay-ish but it's going to be replaced to rule it out.  The main challenge is, I wasn't there for 90% of the work. This is his first time doing any major work on a car and he was learning as he was going. He thinks everything has been put back together properly, however I'm not entirely confident that this is the case.  It would be good to get some ideas about what else to check. The car isn't spitting any codes so that doesn't help.  I've attached a photo, because why not lol.
    • I mean an N1 came with a minimal paint thickness compared to dealer models. It’s probably had a ton of vinyls and stuff possible a race paintjob or two over the years. you don’t buy an N1 for its stunning good looks or comfort 🤣 you buy it to send it and measure how much air you can get on the hill at Bathurst
    • Yeah, but "restomod" implies Singer and things like it, which implies drug money / trust fund maturity.
