Hi Guys,
I'll be getting my RB25/30 conversion done soon, and I just wanted to confirm with you fellas some prices my mechanic quoted me for.
RB30 bottom end with Forged pistons (I forgot what brand, I'll get back to you on this one) with forged rods, all fitted and machined ready to be bolted on the head of the RB25 - $8,700
GT35R 0.82 A/R housing, 38mm external gate, with the manifold to fit thr RB30 and oil lines from GCG for $3,700
$1,300 for plazmaman plenum
$600 for contruction of new dump pipe and some cooler piping
mechanic estimated around $2,000 for labor to fit everything and tune it.
Do these prices sound about right to you guys? All up that around $16,300.
I already have the cams, injectors, fuel pump, PFC, exhaust, front mount etc etc.
Correct me if I am wrong, but isn't $8,700 for a fully forged RB30 engine a little too expensive?
yeah thats sounds pretty exspensive. $8,700
a great set of pistons should be under $1500, rods well under $1500... i'm guessing stock crank just polished or something, ACL race series bearings, mmm not % sure what they are worth to fill out a RB30. guessing a few hundred. machining costs.... and oil + water pump gasket kit..arp stud kit maybe?
mate unless you are getting the best of the bloody best thats sound rather dear.
you'd wanna be getting some high end pistons rods, rings and bearings and a high end oil & water pump.
only thing is you say "all fitted and machined ready to be bolted on the head of the RB25"
is this including the head work or is that just "ready" for you to bolt a stock 25 head on??
i'd probably go a stock internal'd rips long motor for $4300 AUD but make sure it had oil restrictors and custom drain first (haven't really looked much yet)
as well as the baffeled sump option
Sack the idea of using a GCG manifold. Buy something else. I recommend a steampipe deal from ETM (Extreme Turbo Manifolds). He makes tonnes of them to suit RB30DET's and knows exactly where things need to go on a 33 gtst to keep it all under the bonnet. Truly worth the dollars spent (and it doesn't sound like it would be that much extra judging by the dollars you've quoted.
Link is in my sig.
$3700 for a turbo kit seems pretty extreme..
My turbo setup (going on very soon) cost me:
GT35R 0.82ex - $1600 (new but not from a store, at the time the turbo new from MTQ was ~$1850)
TiAl 44mm gate - $420
High mount manifold - $150 (came off a mates car, not as quality as a 6boost or ETM but makes the numbers)
Oil/Water lines - Will be getting Enzed guy out, am anticpating ~$200
I guess if the exhaust manifold included is a 6boost or ETM item then it's not too bad, if it's a china manifold then you're getting ripped off :P
Ok, so for the $3,700 from GCG, you get the following:
GT3540 0.82 A/R
TiAL 38mm gate
High mount Xtr manifold (Xtr is GCG's in house brand)
Oil and Water lines
Exhaust flange for turbo
Gaskets and nuts.
Do you fellas think this price is reasonable?
Also, will a 38mm gate be large enough for my application (RB25/30 with the GT35R 0.82) or would I require a 44mm gate?
Cheers
i think my high mount ETM was around the $1550, including the water and oil feed and return lines made by ETM and it was also ceramic coated, as was the exhaust housing.
looking at your pricing about $2200 for turbo and gate and $1500 for the rest.
i know what i would pick any day of the week
and i would also recomend 44mm gate as a minimum bigger the better really.
GT3540 0.82 A/R
TiAL 38mm gate
Oil and Water lines
Gaskets and nuts.
Cheers
I've highlighted the bits I'd have an issue with. Also, in-house is very much the wrong word to use. They're the same as the better constructed China manifolds you can buy from ebay. They're not worth the money they charge and they don't work nearly as well as an ETM or 6boost manifold in terms of spool, wastegate flow, collector design, quality etc etc etc...
My best (and last) advice on the subject is to contact Leigh - [email protected] / +61 2 42628774 and ask for:
- High mount manifold to suit a GT35R/RB25/30/ECR33
- 44/45mm Turbosmart wastegate
- Oil and water line kit
Good luck mate.
All the best,
Adrian
Sizing of gate kind of depends on the boost you're going to run.. there's a big thread round here someone on the subject.
I believe it goes along the lines of (roughly), the less boost you want to run the bigger the gate you need (as you will need to bypass more exhaust gas from the turbine).
Short motor does seem a bit excessive..
As far as turbo set-up goes.
Mine all brand new
GT3540 1.06 A/R = $1500
6 boost manifold = $1000
Tial 44mm gate = $450
Edited by Tomek
How much power are you after? Do you really need forgies?
I would personally buy the RIPS standard RB30 for AU$3300 or spend $4300 with the head. They can probably beef it up a little if you want and will cost u a lot less than your quoted $8000+
I am aiming for 370 + rwkw.
So forgies are a must.
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
