Here's a question for ya, you mentioned a plazmaman plenum. Will this fit under the bonnet with a RB30/25 since the RB30 will raise the engine height a bit? Because i've looked at mine before and i swear with the extra height of a RB30 the front of the plenum will hit the bonnet.
^^^^^Have you seen what else they have run on the stock bottom end. There is a recent post by rips in the rb30 section. A built standard bottom end will handle that with some mods.
quote from rips
I can also vouch for stock RB30 cranks to 9000rpm 1000+hp, and stock RB30, pistons and rods to 8000rpm and over 500rwkw in a track car without problems, although I usually tell my customers 7200rpm, 1.5 bar 400rwkw.
If have money to burn.....
Edited by Bond
Why dont you guys just build your own engines? Do a bit of research like everyone else (there is so much of it on this forum its not funny) and instruct an engine builder to build it to your specs. You could do it for half the price
Agreed... Between the PDF, Oil control thread, and the conversion thread theres not much else you need.
...apart from the tools, the time, the space and the confidence that you wont make an elementary mistake that will involve having the engine pulled and the job done properly by someone you should have paid in the first place.
because i'm lazy and rips are experienced and well reccomended
haha +1
Furthermore, I just don't have the confidence to do it myself and ask a mechanic to build it. WHat happens if I get something wrong, I can only blame myself, whereas if the mechanic does it all, and something turns out foul, you can point the finger/gun at him.
But yes, as always, there is a premium associated with the mechanic doing all of this.
I guess it's too late anyways for me as I've already paid the mechanic.
Might be different in a 33 but I looked at that and it definitely wasn't going to fit in my 32. That is why I had a custom manifold made out of my stock runners and a 26 plenum :D
+1
Yeah thats what i thought. I dont think a plazmaman plenum will fit under the bonnet on a 30/25 in a skyline. Might have to look into this Turbz-RB25.
Correct me if I am wrong, but isn't $8,700 for a fully forged RB30 engine a little too expensive?
my old boss had to fork out roughly 10k on his rb30 block but that had block strengthening done to it as they prone on cracking
plus depends what brand you're using, also you're getting it all prepped for the forgies to go in, so yeah i'd say maybe not quite that
but very close to it
Prone to cracking? More info please, RIPS 8 second stock bottom end seems to differ. The only part of the rb30 "prone" to cracking is the oil pump, and thats if you use something other than an rb30 pump.
For $8700, i would be wanting a high end oil pump.IMO its the first place you should spend the money on an rb bottom end(although i didn't)
This is what is included in the package:
Used RB30 short engine
Drilled and tapped to fit RB25 head studs
Engine is stripped and chemically cleaned
Block rebored and torque plate honed
Head gasket surface CBN milled to suit MLS gaskets
Crankshaft balanced, micropolished and fitted with screw in oil gallery plugs
Oil pump drive collar supplied and fitted
Connecting rods resized, fitted with new bolts and pin bushes and balanced
Short engine assembled using new forged pistons and rings, ACL race series bearings, new N1 oil pump, seals, painted and fitted with oil & water plugs.
Plus the mechanic is porting the head, as well as fitting the bottom end to the head.
So it's not just the engine itself, it's the porting of the head and fitting the block which raises the price to $8,700.
Not to mention that exchange rates have an impact upon parts, so stuff would have been cheaper in june 2008 when our dollar bought 0.98USD.
Cheers for your help fellas
eeeeeeeeeek your telling us its $8700 for a $3000 port job and then $5700 for a basic rebuilt with stock rods and crank?
Sorry, rods aren't stock. they are spool RB30 forged H-Beam rods.
They cost around $850 just for themselves.
So you guys still think it's expensive?
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
