Mahle Pistons - Group Buy
shanef
 Share
Hi all,
I've recently found a supplier in the states for Mahle pistons for dirt cheap. The company who are supplying them are Race-Mart.
They have the full range of Mahle pistons and prices are as follows:
RB25 86.0mm 11.5cc dome 8.5:1 CR 343g - US$635
RB25 86.5mm 11.5cc dome 8.5:1 CR 344g - US$635
RB25 87.0mm 11.5cc dome 8.5:1 CR 345g - US$635
RB26 86.5mm 16cc dome 8.5:1 CR 312g - US$869.67
RB26 87.0mm 16cc dome 8.5:1 CR 313g - US$869.67
RB26/30 hyprid 86.5mm -4.5cc dome 8.5:1 CR 320g - US$635
RB26/30 hybrid 87.0mm -4.5cc dome 8.5:1 CR 321g - US$635
All prices are excluding shipping which will be approximately US$41.95 per set of pistons.
All payments need to be made and cleared by Friday 23 January, and order will be placed that evening.
If there are any other Mahle pistons you require, let me know and i'll grab a price.
cheers
Shane
Prices in AUD please.
MRXTCZ
Price in AUD will be dependant on the exchange rate on the 23rd, or if i place the order sooner. Main reason is i'm buying them in USD and i'm not making a cent on them and i'm certainly not going to cop extra charge if i set a price in AUD now and have it change on the 23rd.
However at the current exchange rate via xe.com, the 635 sets are ~960 delivered, and the 869.67 sets are ~1295 delivered
I will know definate shipping prices tomorrow morning, as i'm getting them to give a solid shipping quote (in USD)
Added to the list are EJ20 pistons:
EJ20 92.5mm -12cc dome 8:1 CR 348g - US$421.33
EJ20 93.0mm -12cc dome 8:1 CR 353g - US$421.33
Also shipping has been confirmed, shipping will be US$50 per set of pistons shipped direct to each individual.
Yeh i havnt seem them in an engine first hand but i believe you have to space the oil squirter and turn it so they clear
yeah it was like a few hours fu(king around to get the 1st one worked out and 10mins to do the rest...lol.
you have to work out a happy medium between clearing the piston skirt and the crank counterweight...also between the piston bracing from the gudgeon pin to the skirt and the conrod.
do you have the exact spec of the spacer you used ??? it would helps us alot !!!!
thanks in advance .
 Share
    • That's the most absurd thing I've ever heard. I would go cut bellhousing over that monstrosity of a flywheel all day, every day. It puts a lot more mass further from the last main bearing. I've had nothing but problems with Collins in the past and refuse to ever buy their products again. I would not trust anything they tell you. He's playing his salesman card.  I'm currently at 640whp on a mustang dyno (~770bhp) with the intentions of running E85 and a lot more power this upcoming spring. Cheers,
    • Nah, it's not the reduced knock margin. It is a direct mechanical effect of having to initiate the combustion earlier, while the piston is still rising, which starts to exert combustion pressure on the rising piston earlier, making the rest of the engine work harder to finish driving the piston up to TDC where the combustion pressure stops being a negative and starts being a positive. Your modern engine that only needs ~10° to make MBT doesn't waste the other 10 or so degrees of crank rotation. That's almost all of it. The difference in knock margin might go either way. Remember that modern engines to which you are currently comparing the long tractor engine (the RB) are now running super high compression, direct injection, tricky cam control and maybe even cylinder pressure sensors. You're not comparing apples with other fruit. It's apples and sea weed, or some other evolutionarily primitive vegetation. And remember, squish only really comes into play at the very end of the stroke. It certainly does good things, but it is not the biggest contributor to what's going on. It is quite possibly much less important in 4 valve head than 2 valvers also, because there is so much less squish available to a 4 valve anyway.
    • Food for thought, a longer stroke motor would need less ignition timing vs. a shorter stroke motor requiring more ignition timing.
    • Thanks Duncan, HART is only 10 mins from me (I did my bike license there), it'd be awesome if it ran these types of things.  Sutton Road does look good and they take fewer cars than SMSP which is good.  Surely you have enough land to lay a few million tonnes of concrete and some sprinklers D?
    • I thought an engine that needs more ignition timing to make power is going to result in less power due to reduced knock margin? More time for the combustion to propagate -> more time for it to heat up the rest of the mix to detonation.
