My r33 gtst is the first car i bought myself. My problem is christmass and new years are expensive times. I shouldnt have bought a car on the 14th of january 2008. because on the 14th of january 2009 insurance, pink, green slip, rego all has to be paid right after the hollidays lol.
just some advice to somebody who is wanting to buy a car at this time of year, DONT!!!
Yep I will vouch for that. My daily driver rego runs out on the 19th of Jan.. But we dont get any extra time to do the whole thing. I got my rego renewal the day before Christmas ( thanx santa-Fat C#nt ! ) and most places are shut until early jan. So now I gotta rush around like a maniac chasing down Pink slip etc....Pain in the Ass....And what the hell is it with the prices of Greenslips these days?Bastards just dont know how to go easy on the public
Did you buy in with no rego and register it on the 14th of January last year?
Trying to follow the fact you bought a car the same day rego was due?
probably fresh import bought from a dealership
It sounds like a pain in ass to register a car in NSW...
In the ACT we just pay one lump sum every year that includes rego and CTP and we dont have compulsary inspections either, once the car has passed its first inspection as long as you dont get defected and you dont let the rego run out for more than 12 months you dont ever have to have it inspected again.
I guess we have a pretty good deal going down here :P
I guess we have a pretty good deal going down here :)
Yes... my cousin drove around in a Subaru DL wagon, and the only reason why it was deemed "roadworthy" was because of that rule. I tell you now, having a manual switch to turn on and off the reverse lights because the signal from the gearbox doesn't work is really good for scaring people at traffic lights :)
yes NSW SUX........
everything is worse here especially the law would be more strict to the highest populated state in australia.
its a jungle sometimes.....
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
