  • Replies 287
Posted Images
http://au.youtube.com/watch?v=0LO2e57UtkE&...feature=related
this is the day I fell in love with skyline's, I sat on the back hairpin and was just blown away with the grip the Gtr had out of the corner, will never forget it, pitty the brakes didnt last!
The Sierra's were serious competitors on par with the GTRs at Bathurst (only have the 1990 to 1992 greatest moments from bathurst videos to base that assumption on) if only the reliability was sorted out
Yes this is true they were only restricted in the years after they thrashed the assss of every one then still bet them and the other teams turned around and said ohhh come on guys let us play ....... or we will make it V8s only sadest day ever GOD live the GTR king of them all........You are most childs dream to own one .........
Actually there's many reasons that they went to the V8 format that they have now...One being the GTR but do you remember the racing format back then??? Timed races?? BORING!! They had dwindling spectator and competitor numbers and if you watch any bathurst from back in that time they had everything from GTR's and sierra's to suzuki swifts to make the field up! They had to do something to make it viable, so the V8 format was born....
If i remember rightly as well, the sierra was only running 8 inch wide rear tyres?? With over 500hp outta em and rear wheel drive on an 8 inch wide tyre i beleive that traction was a major issue...And if you watch any of those races from that era every slow speed corner the sierra is in wheelspin! Twas an awesome car though and ahead of its time as was the GTR!
I've got a DVD from 1991 of highlights of the races and i know exactly what your saying about the grip outta the hairpin's at Mallala!! OH MY GOD!! So awesome!! LOL!!
They invented the V8 supercars to keep the GTR out. Having your arses whipped and handed to you 3 years in a row does that to the Holden-Ford community. Throw a GTR in the ring today and it'll still whoop them. :(
What was this thread about again? ... oh yeah ...
So who is is keen to take there car on the track??? keep the hooning off the streets :)
I'm upgrading my brakes soon. Sometime after that I'd be happy to take the "wagon" for a few laps.
Engine service - check
Auto serviced - check
Oil/filter change - check
Good rubber - check
Brakes - to come
generally as it hits 100deg C water temp, and probably 110 - 115 oil temp. Oil breaks down at 120deg C, and coolant will boil around 110 - 115deg C. As long as when you hit these temps, you get off the noise and cool it down for a few laps, you should be fine.
haha noo noo will definaly be keeping sober and eating my brain food before hand for this one lol. u gonna be there damo? this thread is too massive to retrace thru and find out :D
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
