Definately bring more fuel Chad - and you'll need pads too. More grunt = more brake use at the track. I'll be taking full tank of fuel + 3 jerrys - which will only increase once there is E85 in the tank!! I'll have to get a fuel truck from work!!
  • Replies 287
Posted Images
Daniel,
The oil control mods are essential if you have a high powered GTR, especially once you go semi slicks and proper race setup wheel alignment. How many killer wasps are you making now? If you haven't much track experience, and are running street tyres, an overfilled sump will generally do the trick - because you won't be pulling the cornering G forces and using the engine high in its rev range as much as once when you are relatively inexperienced on the track. Not having a personal go at you or your driving, its just what people normally do :)
+2 This is good info!
That's a f*cking crazy list of oil mods!!
Would fitting a larger, gated-baffled sump with a standard oil pump fix the oil issue to a certain extent? Or will that just pump more oil into the head due to the larger sump meaning more volume of oil?
I'd say a N1 water pump is just about standard these days on GTR's when they get the 100k service!
I run my GTR with the oil restrictor in the head and I have a normal sump its just baffled.. I still over fill the oil a Litre and half even with all this done and I am only running 280-300kws
I dont run an oil cooler as I find the temperatures are not to bad..But it would still be a good idea for me to do.
When I first took my GTR I didnt have any of this stuff done to it and I just overfilled the oil and I used semi slicks ..Did you get your car checked over by a mechanic before you brought it? If so I would top up the oil, check your brake pds and fluid and go out and have some fun
Wish I was coming out with you guys!
How many sessions do you guys get in one day?
Yeah it's had a compression test (wet + dry) (170psi across all 6) and a leak down test (3% variance across the cylinders) so the motor itself is in top notch.
Thats great then, Just over fill the oil a little, Check your brake pads and put new brake fluid in it and away you go!! Everyone has different opiouns about the oil issues RB26 can have..If you spew out oil over the day just check the level and top it up a bit more...Do you have a oil catch can fitted?
Street tyres will be fine if it's your first go just need to get some heat into them :)
Nah standard ventilation system... I'm still running stock boost with the stock restrictor in, so I didn't think i required a catch can system.
You could be surprised..cause isnt it high revs which causes the oil surging not boost?? Blue32 isnt that right :)
But it's all a learning thing tho and what works for you..What suspension has it got?
I ran 230kw out there with no catch can and all was fine.
Thats awesome value for money!
Much traffic on the days..
last time i had 4 other cars on track with me in the no cams licence group. Plenty of uninterrupted laps, it was awesome :)
Cool :)
Do you run street tyres? what do you rev it too?
With that power i had street tyres and did a 1.25.00 and i try'd not to rev it over 7000rpm
This time i have 300kw, semi slicks, half cage, and i want to fit a oil cooler before i go out. I don't think I'll be running it at full boost though.
Edited by DSTROY
:) What's full boost 21psi?
Thats going to be awesome fun this time!! I only ever run 1 bar (14psi) and thats enough for me ;)
Standard suspension ;)
But coilovers are on the books... only issue is, my driveway where the car gets parked is like vertical lol... so I'd scrape the entire undercarridge if I set it to anything below stock height... unless I just adjust it each time...
Car is basically stock... except with twin pods, front strut brace and heavy duty clutch... oh and a pretty lame exhaust.
Stock suspension isnt a bad thing if it's in relatively good nick ;) You should try the car out on the track before you get your mods and then you will know what the car really needs if Track work is what you want to get into.
I went more handling in my GTR than power..I still havent reached the proper potential of the car with me driving cause my partner gets in my car and driver atleast 3-4 seconds quicker than me..Im still learning to go fast :)
We all have to start somehwere..I do like the White R32 GTRs :)
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
