  • Replies 287
Posted Images
I think I'll be timing officially this time with a proper track timer - plus the old man will bring out his mega uber camera so pics will be available after. Gonna strap the video camera in the car too - so track footage should be cool.....
im keen to try and make it out. if i have enough time / money to get my car reddy.
what time do u have to get there?
I think last time we tried to be there by 8am, gives plenty of time to sign in and get the car all set up.
bit more camber for the track Chad?
I wish, but i dont have any camber adjustment. Just gonna make sure its all lined up right, cos the toe in on the back looks way out on one side.
Im keen to come have a look, interested in getting my car into this sort of thing, goes well through the hills but would imagine it would need a few tweaks to get the power down around a track and run a decent time. Im interested to see a few of the set-ups other higher powered GTRs run.
A few questions:-
Is Anyone alowed in the pits?
Does the day still go ahead if its a hot day?
What time it start, and how much $ to spectate?
Cheers
Andrew
spectators are allowed anywhere except the "car park" where the cars line up to go out onto the track, and the track itself. The cars all park around the sheds, you can only have one opened if you pay for it. So when people aren't racing, you can wander around and look at everyones cars, if thats what your hinting at :thumbsup:
A few questions:-
Is Anyone alowed in the pits? YES
Does the day still go ahead if its a hot day? YES, but if its to hot i wont be going.
What time it start, and how much $ to spectate? starts about 9ish i think, and entry if free for spectators.
Cheers
Andrew
started fitting my oil cooler on saturday, just need to fit all the lines and buy some new brake pads, get front guards rolled, wheel alighnment and i should be all ready for Lala ;)
Would the exact same mounting work for a 32 gtr? my cooler kit is coming soon (same except only 16 rows and braided lines) and I don't even know how to take the front bumper off.
How did you make up those mounting brackets?
Im pretty sure it would mount the same in a GTR, depends on what BOV you have? I've got a single aftermarket one so it doesent take up much space.
I made up those brackets at work just using some 3mm alloy sheet that i cut up in the gillo.
looks the goods Chad.
Have to put my brake ducts in this week as well as change engine oil, put fire extinguisher in, and do a full check of the car.
Just wondering if i take my back seat out do i need to block the hole off to the boot?
It should be fine Luke, there's no car checks or anything.
    • Cleaner signal so timing is more accurate at all rpm also found it to start more on first rotation but could also be I've nailed prime and crank fuel. For under $400 and 30mins of your time, its a good solution especially once the optical sensor does start to play up you won't notice it until in higher rpm and it heat soaks.
    • On a 400hp RB, what benefits other than "it's not 30+ years old" are you seeing from the NZ Wiring Kit trigger setup? If it were me going to change triggering, my belief would be to go for a crank trigger to remove the issues caused by what people claim is belt stretch etc, but that's from my understanding a much larger issue for super high power, rather than those in the 400hp and below club.
    • The NZ wiring kit is a 1/3 the price and will be perfectly fine for your application, I've ran one for 6+ years and many others have. Comes as a full plug into factory connector and the settings for a Link. https://www.nzwiring.com/index.php/product/trigger-kit/ Always comes back to the tuners knowledge and experience with a tuning platform. It takes years to become proficient and learning all aspects and capabilities. I've been using Links for 16 years now (rb and sr paltforms) and always learning something new with adding tables, diagnostics and data logging. Stay 98 for the usability and keep it simple so you can enjoy the car more. With experience I'll give you a current example of the industry I am in. They use Motec m190 and only use VE tuning when they have a torque mapping available and would solve the "PARITY" issues that plagues the category all because the muppet doing the tuning doesn't understand the platform or want to learn it and the product seller have no idea on its full capabilities ( I had a good laugh as when firing up an older car that just got completed and they didn't understand the injector scaling or how to change it for different fuel being used)
    • I'm sure there are specific hygrometers for it. But if you can just throw a high enough ranged temp sensor (theromcouple that came with your DMM, for example) into a pot of it on the BBQ, you can see when it boils.
    • I have multiple bottles in a shed that gets hot, and I'm in SEQ, so it's humid. Maybe we test their theory... Anyone have a system to accurately measure moisture content in oil?
