Hi all
Have an almost brand spanking new NGK/NTK O2 sensor for a R33 GTST or R34 GTT, I only used it for about 500km. These things are supposed to be replaced every 40,000km to improve idle, fuel economy, general performance.
It is the Ford EL Falcon type and comes with the Ford harness/plug so there is no need to worry about the stainless wireless not being able to be soldered. All you need to do is connect these wires to the cars harness wires (that part will solder fine). The Ford EL Falcon sensor is known to work fine in our cars (unfortunately doesnt work for GTRs since they use a different element)
Comes with the original NGK/NTK and leaflet. Took me a while to get the Ford plug for the harness side and thankfully I did otherwise I would have had to crimp the connections which wouldnt have been too good for a sensitive device.
Link to thread about O2 sensors: http://www.skylinesaustralia.com/forums/O2...sor-t43095.html
After installing I noticed it being slightly easier to rev the car out, but above all, it definitely smoothed my lumpy misfire-like idle.
$50 including the Ford sensor
Located in Sydney, can post easily.
Thanks
https://www.sau.com.au/forums/topic/251645-r33-r34-o2-sensor-ngkntk-50/
  • 5 weeks later...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
