got my splitfires from sinergy they keep them in stock, cost about 500 for all , cheaper then OEM and the car runs heaps better, no misfires , smoother idle. seems like more pull to redline now, sputtered a bit before around 6500. money well spent.
no idea on injectors but ultrasonic clean stock GTR items might be the go ?
sweet man thats i will go there 2morrow and get some, thanks again
Don't waste your $$ if you don't have to.
Grab a $13 tube of sensor safe grey silicon plaster your coils and they will be good for 24psi+.
Over 1.5years ago mine were no good for more than 12psi. Since then I've been running 20psi through them. When tuning we pushed in 24psi with no signs of ign. break down. :)
Edited by TheRogue
using dielectric silicone wont fix a dead coil pack but will keep a misfire from occurring from arcing to the head or other voltage leaks , I had a dead coilpack so replaced them all instead
the splitfires use a higher saturation voltage then OEM to achieve the kw power increase, also keeps the plugs from fouling but will wear the electrodes faster too.its not heaps more power but enought to feel in the seat of your pants , maybe a few KW tops but the drivability is better
sorry didnt read the thread close enough, thought it was a GTR motor. mines a RB25DET NEO for the record. call Sinergy and speak to Rocco to see if he has your coilpacks before driving out just to be safe. they stocked mine. and a few others. NS, ETC.
    • Honestly, for a daily I would gladly rock a Camry. The more disposable the better. People drive horribly out here and road conditions are awful.
    • Verify it's going into each of the 4 gears in normal acceleration, make sure the torque converter locks up over ~65-70 kph or so at low throttle opening. If you ease into the throttle at those speeds eventually you should get a "gear" between 3rd unlocked and 4th locked. It should downshift eventually if you floor it at 65 kph too. Get some Matic D ATF and drain the pan, check for signs of sadness in fluid and drain plug magnet. Top off to the correct level afterwards. If the transmission is worth saving you can drop the pan on a second drain and change the filter while you're at it. These are not complicated transmissions, at least compared to modern stuff.
    • A seat I find stupidly comfortable to sit in is the one in a friend's Merc Race Car. It even has the huge wings that wrap around your head. Best ever. Only issue is climbing through his scaffolding he put up in the doorway of the car... Ha ha ha. I sat in that seat for a couple of hours doing wiring. Another stupid comfortable seat I find, especially if my back is aching, is my OMP fixed back bucket seat too. I'll just sit on it when I'm exhausted in the garage sometimes to relax!
    • I just got off the phone with Dean from Vosta in Brisbane. They are the ones that do the replica seats and they have a shop full of seats for my to try out. Lovely guy.  I haven't decided whether to go genuine or replicas, I'm leaning towards Genuine at this point but who knows.  Also thinking the STRADIAs are the way to go VS the GIAS since they have a lower hip edge and would be easier to get into. Don't really like the idea of arm rests on the models to the right of this diagram either, maybe they can be removed?
    • From my own first hand experience, keeping power for a fun Street able skyline down at a responsive low 200 wheel KW, is the best. It makes it super drive able through the twisties, you're not just smashing mass wheel spin, or only able to open the throttle for a split second before being at absurd speeds. That said, plenty of people like being morons at more than double the speed limit on public roads and hence are happy with 600whp and seeing 200kmh fly up frequently and fast. Also, at that low 200, a GTR can still do a decent quarter mile, and with a bit of fancy  clutch work (foot, not the parts) can still beat many many cars in a traffic light gp, even in the wet.
