cdorhout Posted April 1, 2009 Share Posted April 1, 2009 Wow, that's great. I thought about the same theory when I did my RB30, but I didn't dare pull that plug out for fear I'd never be able to find something to go back in there. Very good idea!! Link to comment https://www.sau.com.au/forums/topic/251669-rb2530-rb30det-vvt-internal-oil-control/page/2/#findComment-4513236 Share on other sites More sharing options...
SS#eater Posted April 25, 2009 Share Posted April 25, 2009 anybody else doing this mod? im going to give it ago just wondering if there are any others out there who went with this method. Link to comment https://www.sau.com.au/forums/topic/251669-rb2530-rb30det-vvt-internal-oil-control/page/2/#findComment-4555006 Share on other sites More sharing options...
fletch rb30 Posted April 27, 2009 Share Posted April 27, 2009 mate of mine did it and has been running for maybe a year with no problems Link to comment https://www.sau.com.au/forums/topic/251669-rb2530-rb30det-vvt-internal-oil-control/page/2/#findComment-4559984 Share on other sites More sharing options...
cdorhout Posted April 29, 2009 Share Posted April 29, 2009 anybody else doing this mod? im going to give it ago just wondering if there are any others out there who went with this method. I did it after reading this post. Worked great! Plus, I got rid of my oil leak from the external oil fitting in the head. I had the hole in the head welded shut. Link to comment https://www.sau.com.au/forums/topic/251669-rb2530-rb30det-vvt-internal-oil-control/page/2/#findComment-4564353 Share on other sites More sharing options...
SS#eater Posted May 13, 2009 Share Posted May 13, 2009 awesome, going to go with this method. you would be crazy to go external if this is so simple. Link to comment https://www.sau.com.au/forums/topic/251669-rb2530-rb30det-vvt-internal-oil-control/page/2/#findComment-4591481 Share on other sites More sharing options...
bigturbo Posted July 20, 2009 Share Posted July 20, 2009 hi just wondering what the bung does you circled in blue in the last pic?and what you did with it.also do you have to make an oil return for this vvt setup? cheers Link to comment https://www.sau.com.au/forums/topic/251669-rb2530-rb30det-vvt-internal-oil-control/page/2/#findComment-4724667 Share on other sites More sharing options...
psi Posted July 22, 2009 Author Share Posted July 22, 2009 The blue circle is the oil return port for the VVT. The oil comes into there from the VVT valve and this port allows the oil to return to the head and drain away. does that clear that up for you? I pulled it out just to see what was in there! There is nothing that I can see in there that would/could be of any other use! (but I did have to check! hahaahaa) Anyway, DONT pull it out unless you need to.. and I cant see why you would need to.. Link to comment https://www.sau.com.au/forums/topic/251669-rb2530-rb30det-vvt-internal-oil-control/page/2/#findComment-4729041 Share on other sites More sharing options...
psi Posted August 4, 2009 Author Share Posted August 4, 2009 yea mate.. That explains it very well! Now you have seen it... how easy is that to do? Cheers for the pic, I didn't think to do the pic like that..! Good one. Link to comment https://www.sau.com.au/forums/topic/251669-rb2530-rb30det-vvt-internal-oil-control/page/2/#findComment-4749664 Share on other sites More sharing options...
psi Posted August 4, 2009 Author Share Posted August 4, 2009 If you click on my pics of the plugs, its easy to see where I drilled the holes. Now with the new pics above ^^, that should remove all guess work of how it works. cheers Link to comment https://www.sau.com.au/forums/topic/251669-rb2530-rb30det-vvt-internal-oil-control/page/2/#findComment-4749677 Share on other sites More sharing options...
daisu Posted August 4, 2009 Share Posted August 4, 2009 Just to get an idea of how it works, is this what is happening with the oil feed? 1 Link to comment https://www.sau.com.au/forums/topic/251669-rb2530-rb30det-vvt-internal-oil-control/page/2/#findComment-4749248 Share on other sites More sharing options...
works 510 Posted August 4, 2009 Share Posted August 4, 2009 Thanks for the Pm Aaron, after reading it then finding the above pic, confussion all sorted Going to pull the plug out tommorow nite Link to comment https://www.sau.com.au/forums/topic/251669-rb2530-rb30det-vvt-internal-oil-control/page/2/#findComment-4749792 Share on other sites More sharing options...
psi Posted August 5, 2009 Author Share Posted August 5, 2009 Feel free to take more pics and post them up.. I tried to give as much info as I could, so, you should be able to do the job without too much bother. be kind to the plug when removing it.. you dont want to break it in half! or drill too deep! happy modding mate! Link to comment https://www.sau.com.au/forums/topic/251669-rb2530-rb30det-vvt-internal-oil-control/page/2/#findComment-4750629 Share on other sites More sharing options...
works 510 Posted August 5, 2009 Share Posted August 5, 2009 Damn that plug is in there tight! Well its out and getting the drill treatment tommorow Cant belive how straight forward it is Link to comment https://www.sau.com.au/forums/topic/251669-rb2530-rb30det-vvt-internal-oil-control/page/2/#findComment-4751782 Share on other sites More sharing options...
TriniGT Posted August 5, 2009 Share Posted August 5, 2009 I have a Neo engine and I am not seeing the plug you'll have I am only seeing what looks to be a metal slug and a welsh plug not sure if it is the same thing. Any ideas? Link to comment https://www.sau.com.au/forums/topic/251669-rb2530-rb30det-vvt-internal-oil-control/page/2/#findComment-4752004 Share on other sites More sharing options...
psi Posted August 12, 2009 Author Share Posted August 12, 2009 Read the WHOLE thread again! check out post #4. I put some colour on the bit that you need to look at! Link to comment https://www.sau.com.au/forums/topic/251669-rb2530-rb30det-vvt-internal-oil-control/page/2/#findComment-4764597 Share on other sites More sharing options...
JVDSKYRINE Posted August 16, 2009 Share Posted August 16, 2009 Hey i was wondering if you still need an upgraded oil restrictor after this mod? Link to comment https://www.sau.com.au/forums/topic/251669-rb2530-rb30det-vvt-internal-oil-control/page/2/#findComment-4771316 Share on other sites More sharing options...
TiTAN Posted August 17, 2009 Share Posted August 17, 2009 (edited) this mod has nothing at all to do with restricting oil flow to the head, it is changing where the oil goes once it is in the head. Edited August 17, 2009 by TiTAN Link to comment https://www.sau.com.au/forums/topic/251669-rb2530-rb30det-vvt-internal-oil-control/page/2/#findComment-4771688 Share on other sites More sharing options...
TriniGT Posted August 17, 2009 Share Posted August 17, 2009 Read the WHOLE thread again! check out post #4. I put some colour on the bit that you need to look at! Damn what was I looking at??? But in the pic you can see that mine has some sort of ballbearing on the outside, is the plug behind that? Would I need to drill into the ball and then somehow get something screwed in and pulled out and then tackle the plug? Link to comment https://www.sau.com.au/forums/topic/251669-rb2530-rb30det-vvt-internal-oil-control/page/2/#findComment-4772948 Share on other sites More sharing options...
psi Posted August 20, 2009 Author Share Posted August 20, 2009 I han't done a Neo head.. but I'm guessing that Nissan didn't stray too far from what they already know works. Please take another pic, up close and front on, just like mine so everybody can see what your looking at. Link to comment https://www.sau.com.au/forums/topic/251669-rb2530-rb30det-vvt-internal-oil-control/page/2/#findComment-4779095 Share on other sites More sharing options...
bigturbo Posted August 27, 2009 Share Posted August 27, 2009 hey just one more thing on this does it actually work because on the factory 25 block the vvt is getting a direct high pressure feed straight from the oil pump wheres this method is only getting in from the head?also when you other guys are putting the pistons in the block do you put oil on the rings or assemble dry 2 prevent the bores glazing up cheers chris nz Link to comment https://www.sau.com.au/forums/topic/251669-rb2530-rb30det-vvt-internal-oil-control/page/2/#findComment-4792678 Share on other sites More sharing options...
