I left the factory restrictors in since I am already robbing oil for the VCT.
Drilled the oil returns too.
WIll post up how it goes.
Same setup as me, the factory ones are supposted to be 1.8mm. How is it working out for you so far? im tossing up whether to fit a large capacity sump to prevent any oil starvation in the bottom end just as some extra precaution...
With the solid lifter conversion I no longer have to feed the vct orthe hydraulic lifters, I am going with onw only head feed as the 26 guys do ans restricting it to one mil.
Farken sick of too much oil upstairs. :P
just finished doing this tonight. couldnt get enough bite to pull it out without drilling and tapping it a fair way through, but i simply loctited the bolt i used in there and am going to cut it off flush with the front. due to tapping it so far and not having a long enough 1.5mm drillbit i had to put the hole in the side a bit further back, but i had a good look inside the head and i cant see it making any difference.
anyone done anything special to make sure the plug doesnt come out? its pretty tight but i wanna make sure its not gonna move.
Loctite I guess. I doubt it will come out though. There isn't enough pressure or surface area to cause it to push out.
I will post up how I go too. Interested to see if I have too much oil in my head or not.
  • 5 weeks later...
Sorry guys I know this is slightly off topic, but I didn't want to start a new topic. I am currently putting a rb25 vvt head on a 30 and will be doing this mod.. but there is a oil return on the exhaust side of the head that goes via a pipe to the block. So my problem is RB30 blocks don't have this hole in the same place, so would it be alright to extend that hose and use a t piece to let it return through the turbo oil return on the block. Hope this makes sense I can take pictures if needed.
  • 1 month later...
The guide is just so vague with everything. I mean it helps a fair bit with what fits what and so on, but when it comes to the finer things it sort of tells you how to get it done but not really. If I really want to learn how to do this I want to get experiences from others and how they went about it. I mean the guide still says NEO heads may have different oil and water galleries and hasn't been updated so how can I rely on that when going down this path.
If there is any more detailed information available could someone please post a link. Thanks
  • 3 weeks later...
drilled from one feed to the other .. get the angle right or you could end up with oil where you dont want it
picky of where I drilled between the first 2 (intake) cam journals
Drilled and tapped the outer layer to take a bung
Dummy fitted the bung to show what it looks like finished
Head was then dissassembled for further mods before being cleaned an reassembled
Hope this helps people
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
