Wow, that's great. I thought about the same theory when I did my RB30, but I didn't dare pull that plug out for fear I'd never be able to find something to go back in there. Very good idea!!
  • 4 weeks later...
  SS#eater said:
anybody else doing this mod?
im going to give it ago just wondering if there are any others out there who went with this method.
I did it after reading this post. Worked great! Plus, I got rid of my oil leak from the external oil fitting in the head. I had the hole in the head welded shut.
  • 2 months later...
The blue circle is the oil return port for the VVT.
The oil comes into there from the VVT valve and this port allows the oil to return to the head and drain away.
does that clear that up for you?
I pulled it out just to see what was in there! There is nothing that I can see in there that would/could be of any other use!
(but I did have to check! hahaahaa) Anyway, DONT pull it out unless you need to.. and I cant see why you would need to..
Feel free to take more pics and post them up..
I tried to give as much info as I could, so, you should be able to do the job without too much bother.
be kind to the plug when removing it.. you dont want to break it in half! or drill too deep!
happy modding mate!
  psi said:
Read the WHOLE thread again! check out post #4.
I put some colour on the bit that you need to look at!
Damn what was I looking at??? But in the pic you can see that mine has some sort of ballbearing on the outside, is the plug behind that? Would I need to drill into the ball and then somehow get something screwed in and pulled out and then tackle the plug?
I han't done a Neo head.. but I'm guessing that Nissan didn't stray too far from what they already know works.
Please take another pic, up close and front on, just like mine so everybody can see what your looking at.
hey just one more thing on this does it actually work because on the factory 25 block the vvt is getting a direct high pressure feed straight from the oil pump wheres this method is only getting in from the head?also when you other guys are putting the pistons in the block do you put oil on the rings or assemble dry 2 prevent the bores glazing up cheers chris nz :)
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
