hi guys im currently building a 400+kw rb25/30 retaining vct
my head is currently being machined and I need to know what the maximum diameter is that I can drill out the head oil drains?
I have a -12 headoil drain also and restrictors etc but I will be doing the above also, any info or feed bad muchly appreciated
Corey
I understand 10mm but haven't done it myself. You also have to relieve the tops of those holes and the other drains.
  • 5 months later...
Hi, i know this has been asked but i haven't seen an answer to it, has anyone got the internal VCT feed working and controlling oil issues to the head on a track engine?
what feeds are people running to the head when not using an external VCT but the internal drill feed method?
Ive never had this mod running tried it on two different engines with 1.5mm Restrictors and n1 oil pumps.
ended up doing the tried and proven method of external oil feed.
I am not sure if the internal VCT feed method got past the great theory stage. I have seen a couple of people who have tried and failed - don't remember seeing anyone who has actually done it successfully. Anyway don't really see how it relates to oil control problems - you still need restrictors at least and with RB30s I would say you need sump breathers.
hey guys im deleting vct on my 25/30 still running hydraulic lifters though, iv removed and plugged the vct solenoid in the head, obviously the bottom of the head is welded (the vct feed area). and I have 2x 1.2mm oil restrictors is there anything else I need to do?
  • 3 months later...
Hey I read on the Webbers guide page for oil feed mods and it says " R34 NEO heads can be ran without NVCS as there is a normal oil feed" Can anyone confirm this? Or do you think an external feed should still be done?
Cheers Chris
Cheers Chris
Got a link to the guide you were reading?
Oh ok well I intend on keeping vct. But must have read it the wrong way. So I'll still need the external line. Thanx fellas
I'm not saying the internal feed won't work - just that people on this forum recently have tried and failed. If you look at Webber's site (link above) you'll find instructions on how he did it.
Yea I didn't think u could do it internally. From what I read on webers I was under the impression u didn't have to run a external line, even if u wanted to keep vct as the neo operates a different way. But guess it can't so External it is. Thanks guys
  • 1 year later...
drilled from one feed to the other .. get the angle right or you could end up with oil where you dont want it
picky of where I drilled between the first 2 (intake) cam journals
Drilled and tapped the outer layer to take a bung
Dummy fitted the bung to show what it looks like finished
Head was then dissassembled for further mods before being cleaned an reassembled
Hope this helps people
Hey I realise I'm digging up an old post but can you (boost is good) or anybody else help with this mod to the neo head?
This is easy BUT how on earth to you prevent getting chips in the oil gallery below that will be spat through the motor in the future? You obviously can't get to the inside of that oil gallery easily so have you just ignored this? Can you take the plug out of the front and the ball bearing and spring etc and clean it out?
I just notice people talking about external feeds on Neo heads again in here, I can't understand why you'd go external if you can do a rock solid internal mod?
  • Like 1
You drill it with the head off and blow it out.
absolutely brilliant. i was thinkin of doing this also with mine but there wasnt alot of people willing to try it back then and also time was an issue so i went with external. might have to re-visit this! less points of failure!.
    • Update Issues 5 (plus #4) - 10 After making a claim about issue #4's missing part, DeAgostini Japan sent a whole new issue #4 and it arrived about 2 weeks after that. That was back in early March. It took another 4 weeks to receive issues 5 - 13 though. This update is for issues 5 - 10. Ove the 5 issues the front left suspension and most of the engine have been completed. The quality of the castings and fit of the parts is quite good, it seems better than DeAgostini's BNR34 Skyline GT-R from the Fast & Furious 2 movie, which (to me anyway) doesn't seem to have as tight tolerances or quite as accurate castings.  Each issue has a lot of info about the 1989 - 1993 Skyline range and other Nissan models from that era, but the focus is on the BNR32 Skyline GT-R Nismo and the various racing it did in Japan, Europe (Spa 24hrs) and of course Australia. I've included some text translated with Google Lens in some photos and will add to them if there's anything worth including.
    • If it's for a SR20, make sure it's not the American Poncams, might as well call them Poocams. Had a set in a friend's car, all scuffed up after a few track days. Like the metallurgy Tomei USA used is junk. Went back to JDM OG Tomei Poncams, no issues till now.   Tomei USA is not the real OG Tomei.   Random rant over, fk the US of A, bunch of c u n t s.
    • Most of the industry in North America either runs on Siemens or Allen Bradley. I have two redundant S7-1500's on my desk right next to me for simulation. Siemens has been losing ground though since Stuxnet, as cybersecurity is a big thing. In my line of work that is federally regulated, you must by law have a cybersecurity management program in place and its audited and inspected every so often.  I work with Emerson PLC's daily (RX3i's) and have done large biogas/refinery projects with their DCS's. Their PLC's are somewhat OK minus the way they do PLC redundancy (You have to download on both PLC's separately every time you make a change )  As for their DCS's... you'll be limited financially first before anything else stops you. Costs are exorbiant at roughly 10x what it would cost you to do with any other system (e.g AB PAC).  1990's, those suckers are brand new haha! Kraft-Heinz (An old client when I use to work for an ESP) still runs Siemens TI505 PLC's from the mid 80's. Ohh how I don't miss working with those... you could only do a certain number of online downloads until it's "Change" buffer would be full and you would then need to go offline to do a full download. There was no warning of when this was coming up and it generally would happen when you would go in at 2am to make changes before production -_-.
    • Unfortunately, not only is that not the case, one of the main "Selling points" of safety over comms is they clearly state in writing that there's no need to segregate safety networks from non-safety networks. It always gets intermingled with everything else on an ICS/OT network.
