Cyric Posted September 18, 2003 Share Posted September 18, 2003 Came accross one of these on the weekend, was thinking about using it to power a subby, any opinions? Also does anybody know what its worth? 2 channel amplifier bass boost of 18db @ 45Hz treble boost of 12db @ 12Khz 72db channel seperation 105db signal to noise ratio 0.015% harmonic distortion 60% efficiency high pass rca output variable high pass filter 20Hz 5KHz low pass rca output variable low pass filter 20Hz 5KHz mono output @4ohm 300W RMS stereo output @2ohm 125W RMS per channel stereo output @4ohm 75W RMS per channel heres a few pictures as well http://coppermine.e-clips.com.au/thumbnail...ls.php?album=18 Link to comment https://www.sau.com.au/forums/topic/25168-earthquake-250tx/ Share on other sites More sharing options...
Fhrx Posted September 18, 2003 Share Posted September 18, 2003 Nice little amp that would be very well suited to run a single subwoofer. Link to comment https://www.sau.com.au/forums/topic/25168-earthquake-250tx/#findComment-535913 Share on other sites More sharing options...
