I am throwing some steel wheeled turbos into my 260rs stagea and I am not aiming for more than 300rwkw (280-290 would be fine) however tuner recons the afm would be out of range, so got to get something else in there yeah I know the best route is prob Nismo but with the aus $$$ not going to happen, and the Z32 is a good option however I am tempted just to throw in the RB25's, how may people are out there running them in GTR they also plug straight up into the loom. I am also thinking how to mount onto std air box anyone just re drilled the holes into the airbox so they fit??? and just stretch the rubber going to the turbos over the 80mm, will that work????
https://www.sau.com.au/forums/topic/251683-gtr-afm-upgrade/
also interested in this, from what i have read lots have ppl have been limited to around 270-280kw due to afm unable to cope but have also read tuners like ben@racepace simply tune around the limitation.. are rb25 afm same size body or larger?
https://www.sau.com.au/forums/topic/251683-gtr-afm-upgrade/#findComment-4356783
Stock will be fine
Worst case, you can put any AFMs on, you just need adaptors to make em fit.
Better off buying new, simply because they are new. 2nd hand AFM's are a pain if they start failing, by the time you replace a couple you could have brought new ones lasting another 15 years :)
Or have connectors failing like i do making me think it was AFMs :)
So get the Nismo GTR Replacement AFM's IMO.
https://www.sau.com.au/forums/topic/251683-gtr-afm-upgrade/#findComment-4356851
RB25 AFM, R33 are used on the vg25 and vg30 which you'll find in a maxima, a fwd cefiro, 300zx etc etc etc, two of these are three litre engines and have no issues with reading upto 600 hp aslong as you leave enough distance in piping between the afm and the turbo to stop turbulence.
the other trick is to grab the throttle body of a vt to vy commodore with the map sensor and do away with the afm all together
https://www.sau.com.au/forums/topic/251683-gtr-afm-upgrade/#findComment-4359081
What my mechanic told me on this subject was that, the higher you go on stock AFM's the more difficult it will be to tune around them. Obviously there is a limit here but it wouldn't be 300kw, pretty sure Evocoop on this forum was running just under 330kw 19-21psi through stockers with ease.
https://www.sau.com.au/forums/topic/251683-gtr-afm-upgrade/#findComment-4359638
    • Same.  It's depressing to say this but the skyline can go months on the charger between drives.
    • I often leave mine connected weeks at a time. The main one I use is the old model of this, it has 2 important features - choose battery chemistry other than lead acid (most of mine are AGM) - power supply mode which you can use to try and recover dead flat batteries as "smart" chargers often don't recognise a dead flat battery is connected https://www.projecta.com.au/products/IC10/intellicharge-10a-bat-chgr The Ctek I  use was meant to have a battery test mode as well but it doesn't work 100% of the time so I am pissed at them. The distributor did everything possible to make warranty and support difficult so I'll stay away in future. The main thing with a "trickle" charger is it has multi stage programs, ie once the battery is full it turns the current right down to just maintain the charge....in the old days we just used real "trickle" chargers for that which had a maximum output of say 500mA which was safe to just leave connected to dumb old lead batteries.
    • I've heard people claim with Just Cars (now defunct) and have been paid out, but painful process, and with Shannons, but noone I know or heard of has claimed with Enthusiast, hence I'm a bit nervous with their policy. Sure I'm "covered" but am I? is the real question
    • I have the Century CC1206 12V 1/3/6Amp 9 Stage Battery Charger. It is different from the one you linked but I don't know in what way. Their manual says that it both can be left on 24/7 and that it shouldn't be left on 24/7. Go figure ¯\_(ツ)_/¯ I haven't been game to leave it on there for more than 2 days.
    • I don't read the 2nd paragraph the same way, I believe it is defining "modifications" from the previous paragraph, and I'd be happy to have a lawyer argue that in case of an issue.....if they have agreed to it and listed it on the schedule it is covered. Has anyone had them attempt to deny it based on that reading?
