For Sale: 1995 R33 Series 1.5 typeM Skyline GTS25t
Reason for sale: Travel
Modifications: stereo, Bov, Turbo timer, Boost controller, tinted windows, some parts of interior retrimmed i.e. steering wheel, knob. aftermarket wheels.
Mileage- approx 123,000kays
Imported late 2007 with around 89,000kays. Service papers kept. lots of parts replaces including rear shocks, fan, timing belts and power steering belt (115,000 kays). mainly garaged whilst i have had it. serviced regularly but dont drive it much now as i am selling so has not had a service for a couple of months.
Location - Hobart area
Price - 10,000 or nearest offer. i need it gone so if im sure something can be arranged. The car is great to drive, smooth through the gears etc. rides well.
no tyre kickers please.
the picture attached is of the car when i first got it.
https://www.sau.com.au/forums/topic/251716-fs-r33-gts25t/
Manual or auto? Don't really say and 'smooth through the gears' don't give anything away either!! I know somebody who is after a manual without a sunroof. Does your's fit the bill?
Cheers, Greg.
it doesnt have a sunroof but its manual. by smooth through the gears i basically meant it drives well. i dunno what else to say. just put new rear shocks in a few thousand kays back.
https://www.sau.com.au/forums/topic/251716-fs-r33-gts25t/#findComment-4358647
My mate's son is after one without a sunroof for track work. I showed him another one that had a sunroof and he walked away from it quickly.
He has your number, it's up to the God's now!
Cheers, Greg.
ok mate thanks for your help. lets hope the gods help me get rid of it finally!! its been for sale for a long time.
https://www.sau.com.au/forums/topic/251716-fs-r33-gts25t/#findComment-4358702
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
    • So I'm in the final stages of assembling my single turbo RB30/26 and had a question regarding MAP reference points.  I've seen several recommendations such as tapping the cylinder 2/3 ITB, tapping the intake manifold at cylinder 2/3, or using a point on IAC. First two are doable but require permanently modify part and the third is "out" as I plan to delete the IAC.  All that to say my question is can I used the "bleeder" in the center of the ballance tube as a MAP Reference? I'm running a catch can so I don't need it for the PCV system. My thought process is it "pulls" from all 6 cylinder, and it's between the ITB and the cylinders making it ideal for MAP reference according to what I can find. Thoughts?
