Hi, Help please.
I really want my spot light to work. I did read a post regarding this topic but I still can't get it to work. I know there is a plug behind the steering column light stock, I checked, it's pluged in. I tried tracing the H4s lamp wire but can't see where it goes. Anyone knows anything other than that?
https://www.sau.com.au/forums/topic/251717-need-help-on-the-spot-lights/
spot light?
which light are you talking about?
The light on the lower part of the head lamp. Not the fog light on the bumper. The H4 bulb. Apparrently, the steering light stalk control the spot lights, but mine just turn the markers on. But when i use my high beam, both the high and spot light will turn on.
Anyone knows what I'm talking about?
I guess you get the 03 headlights, It seems the previous owner changed the wire and link it to the aftermarket fog light on bumper.
Please classfied, when you turn on the second switch on your steering light stalk (the one inside) what's happen?
BTW, it is usually called driving light.
Frank
Edited by Frank350GT
I don't have any fog lights on the bumper. When i turn the switch on, only the side marker (the 5W bulb which runs from top of the head lamp to the bottom on each side) turn on. No lights.
Chris where in the passenger door you are talking? do I need to talk anything off? I don't see anything from the outlook of the door.
Flying,
I think Chris means ... Look for the purple import plate that has been riverted to the passenger side intrusion bar/door area (open the passenger side door and u can see it). :cool:
Edited by Wilby
I have 4 levels of lighting on both my v35s. parker, yellow halogen driving light, xenon headlamps, then highbeam. Thats normal right?
I think all that 4 different lighting are standard on our car, but now I'm missing the yellow halogen driving light you are refering to. So mine's not normal!
Oh, I don't find any purple plate there but I found a dark red sticker under the bonnet and it wrote it was complied by IAMSHE Pty Ltd
Edited by FlyingEL
that tells me whose sheets he used. pull the stalk off and pop the back off of it. there will be a 3 pin plug on it that snakes back into the stalk. check that it is plugged in on both ends.
Hi Chris,
Just did that, pull out everything, both ends are plug in. What other problem can it be?
  • 9 months later...
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
    • The axels in my R33 seem tired, and have a bit of play in them. I cannot find any new of course, not interested in buying used, but I am looking to see if anyone can identify some cross compatible axles. In the states I have seen suggested for S chassis the J30 axles, however for the skyline (as best I can tell) the lengths are about an inch off (2.5cm) on both sides. R33 my measure L 22" R 24.5" GPT L 22.5" 24.25" J30 L 23.5" 25.5"  so shaft length is probably an inch wider. Not sure if someone has another still remanufactured option besides the J30. I figured worst case I can buy a pair tear them down and swap the center shaft. My other option was reaching out to GSP to see if they cannot piece together a set, since the axle stubs are still manufactured, I wouldn't think it be that hard to find a shaft or make a shaft work.
