coby extractors (about $350) - www.partsco.com
fujitsubo extractors - (about $2500) - www.takakaira.com
i only have experience with coby extractors (quite a few others on here have them) and they gave a lot more low to midrange power making the car a lot quicker for normal, everyday driving. i maybe lost a little top end power, but it may only feel like that due to the increased low to mid power (if that made sense). i highly recommend them.
i too have the coby extractors, and gregs right, low-mid is great, however i didn't notice that drop in top end - it still kicks at 4-5 thou, and stays on a little longer if anything. the 2litre might behave a bit differently though.
I was thinking about that sucking noise under power though - has anybody stood in front of the car and revved it to see where the noise is coming from? i still have the stock airbox and intake snorkel, and the noise is still quite pronounced. Might be noise of flow through the extractors themselves rather than the intake...? ill have to have a closer listen on the weekend....
what i was trying to say is that the top end power was probably unchanged but it just felt less in comparison to the power that was made available in the low to mid range. still making no sense!?
pstanbis, the sucking sound is very annoying isn't it :rofl: i was told by an exhaust shop that it is resonance in the extractors. ways to reduce the noise (by muffling the sound):
. wait for them to be coated in carbon/exhaust residue. mine quietened down after about 1500km's, but only a little.
. wrap them in exhaust wrap. i considered this but its quite expensive, if not done properly shortens the life of the extractors. its a bit of a hassle to take the extractors off, clean them of all rust etc, then paint, wrap and paint them, and then put them back on.
I was annoyed at the fact that it's very hard to run a cold air pipe from lower bumper to the filter box - coz as you all should know, the air flow through the filter goes DOWN. Instead, I got a K&N pod and made a FULLY SEALED (screws) and INSULATED heat shield from aluminium sheet and ran a 3" PVC pipe up onto the pod. Runs fantastic on the higway.
Greg,
Cripes - I'd love post a pic but I don't have a digital camera. I'll Explain it differently :
Air enters the scoop just above the radiator and flows into the top half of the filter box, passes through the filter into the bottom of the box, then runs off to the throttle body.
A cold air feed pipe normally runs from the bumper area directly into the filter box, but with the above setup the pipe it's a lot harder to get a large sized cold air pipe to feed the top half of the filter box. So I just went for a pod and a pipe that feeds the pod.
Does that explain it better?
hey greg i now have that sound ur describing. i got the resonator and middle muffler taken out of the hks system and it now sounds so bad i dont want to drive it. i went back and got a new resonator which almost cured it but the car is too quiet now, i was thinking of selling the hks system but im now not gonna bother as the new engine is on the cards.
hey john sorry to hear your exhaust sounds shit! i was considering removing the middle muffler to give it a tougher sound but now i've read that i won't bother.
i finally discovered what was making the sound, this might help you, here's the story:
I was driving along and all of a sudden my exhaust got REALLY loud. i stopped and looked under the car and sure enough mr muffler (who fitted my extractors and cat) had failed to use split washers and the bolts on the cat had vibrated loose, letting exhaust gas escape. so i drove around for a bit enjoying the exhuast note (:() and then took it home and reversed onto ramps. i removed the cat and discovered two things:
1. mr muffler had combined 2 broken gaskets to try and make a good one, it obviously failed.
2. in the cat there was heaps of little drops of weld mr muffler had failed to remove.
these 2 items were the cause of my dodgy sound - the leaky gasket and the weld droplets. so i reused an old gasket i hard lying around (it was heaps better than the ones mr muffler installed) and vacuumed all the weld droplets out of the cat. the exhaust sounds awesome now and i'm going to take a sound clip soon and post it up (just for your joe, if you're reading this :D),
cheers
greg
I was going to get some extractors soon!
Why the huge difference between coby extractors and fujitsubo extractors??
Does it make a big enough difference to warrant the noise and money?
Secondly I only have a stock exhaust and would change at the same time! What brands would be good at reasonable price?
Can any one tell me the KW given before or after? I really have no idea what the power of my NA R33 is???
  • 2 years later...
I'm thinking i'll go for the K&N panel filter and try to incorporate twin air vents on each side of the bonnet for better air flow. Might try getting some stiff pipe hooked on underneath the bonnet going from the air vent to the air box. I might also try some flexi pipe running from the botom of the bar into the engine bay. Just ideas.... :P
Also, can anyone recommend some Brand name extractors and their experience with them? what kinda power boost should i be expecting?
i have a 91 R32 GTS with a RB25 n/a and i have just changed my ashmatic air filter to a proper k&n filter and the power difference was amazing. and i have also had fited a set of custom made pacemakers fitter to it about a year ago and it has a 2.5" exhaust right through to a super cat muffler. sounds awesome. power increase wasn't neck breaking but better. but had way better sound and in gear acceleration.
  • 4 weeks later...
    • @Lithium  looking for a turbo for my Rb30. Want to make sure I understand this correctly.   If I want to stay 40psi or under my best choice of these 3 is actually the smaller G40-1150 ?
    • Massive ups for MTHire also. Could not have done the subframe bushings job without hiring the tool from them. Process was super easy and cost me around 25% of the cost of the tool. If you need a one-time tool to do something, check them out. (Paid for the rental myself, no sponsorship here.)
    • I'd suggest calling Unigroup, they have a lot of experience with these, access to reliable fabricators etc. Of course it will cost but at least you can trust what they tell you
    • The switch part, is the switch you use to turn the lights on and off in the car.   The test I had was to determine where in the line it is, but on a quick rethink, if it's only blowing when you turn the switch on, then it's the wire from the switch, to the headlight that's got the short. Now it's a case as GTS said, of physically finding the fault. The fault could be:  metal has broken through the loom. Known as a rub through. Places to check: anywhere the wiring has been messed with in the car, particularly firewall grommets if extra cables have been passed through. Check the inner guard linings, you might be rubbing through with a wheel, particularly if the vehicle has been lowered. Also check for anywhere there could be high heat, especially if heat shields are missing. Double check any wiring at the head unit too if someone has messed with the headlight wiring to pick up a feed to dim the headlight at night. You could also just have really old cabling that is literally falling apart, though, this is more likely in Euros than in an old Nissan in my experience.
    • Yeah. I usually go by the torque specs. I forgot that Nissan recommends 1386b sealant on that thread, still can buy it on ebay actually.
