Recently my radiator decided its going to leak trans fluid so i replaced it, started her up and its leaking from the exact same place as my old one....... I think its a bit strange that the radiator i got to replace it would do the same thing as my other one so im beginning to think its not the radiator that is causing this to happen. Any ideas??
https://www.sau.com.au/forums/topic/251758-radiator-leaking-trans-fluidhelp/
If you are talking about the radiator, then it won't leak transmission fluid, it will leak radiator coolant. What colour is the fluid? Is is watery or slightly oily?
If it is transmission fluid, it could be from the power steering pump or lines and if your car is an auto it could be from that or the transmission cooler that normaly sits in front of the radiator.
My transmission cooler and radiator are one piece
Edited by Slow S13
mite be you id hoses, they maybe split or the like. if they are go done 2 autobarn and yea new ones, think its 10mm id hoses not 100% sure on size and length, will need 2 top up on auto trans fluid.
the auto radiator has a chamber to cool the trans fluid with an inlet and outlet.
thanks heaps and yes my trans cooler tank is part of my radiator. Found the problem and was in the most stupidest place that i would have never found in a million years...
Car has been running perfectly for more than 2 days now, thats a record!!
