G'day
i guttered my car a couple of weeks ago, and busted the front left control arm and the castor rod...
I got a second hand set, and i'm trying to install them, but i just can't get the castor rod joint (where the bushes are) to slot in place so i can get the bolt in.
I've got the control arm attached fine.
Anybody got any suggestions as to how to finish the job??
I haven't driven my car in 2 weeks..... :goddam:
please help....
https://www.sau.com.au/forums/topic/25176-need-advice-on-castor-rod/
should put that part in first, do it up lightly then you should be able to move the wheel forward a bit and get the other 2 bolts into place, have a look for a thread about front sway bars, description in there about the castor rods!!
My stock ones virtually fell out last week when i swaped them over for adjustables. They had stuffed bushes.
The adjustable ones were set about 5mm shorter. I needed a mate to push pretty hard on the brake disk so i could get the front bolt in but that was it.
I had it jacked up under the crossmember and my suspension doesn't have a lot of travel and it wasn't too difficult.
