Ok, Ultimate is being delivered to the following servos over the next few days (I get the schedules emailed daily to me):
Monday:
Glenrowan South (prob not a lot of help)
Thomastown Keon Parade
Chadstone, Warrigal Road - good amount going in here
BP Elwood
BP Eltham
BP Big Pine, Frankston
BP Longwarry Outbound
BP Rooksby (Canterbury and Rooks Rd)
BP The Tulla - Melbourne Airport
BP Pakenham
Saturday (today):
Fitzroy - Johnson St
Glenroy (Pascoe Vale Rd)
Heidelberg Rd, Fairfield
BP Seaview, Rye
BP Edithvale
BP Moonee Vale, Moonee Ponds
BP Kealba, Sunshine Av
Wantirna, Wantirna South
Burwood, Burwood Hwy
Springvale, Springvale Rd
Burwood East, Blackburn and Burwood Hwy
Caroline Springs
BP Whitehall, Footscray
BP Tecoma, Burwood Hwy
BP Glenrowan North
Hope this helps, Sunday is floating around somewhere, will dig it out later if I get time. :D
  • Replies 41
No berwick BP? :laugh:
Checked just for you, Berwick is tomorrow's run and is 14,000 litres so a fairly good amount, 8000 is low and 24,000 is very good. Has a note on there saying "AM Request" so would say head down late morning and the driver has 2 drops before it. It is a special Ultimate delivery, no other product. :D
Got to scoot, g/f getting angry as we are running late! Will respond to any others in the morning.
From what I understand it pretty much all comes out of MOBIL Yarraville? I'm in the transport industry ( not fuel ) and always will chat to a tanker driver when filling up the truck and they all say its the same shit coming out of Yarraville.
Last one I spoke to did say that Shell tries to use there own as much as possible as they have there own tank in Yarraville thats fed from a pipeline from the Geelong refinery but if its empty then it will be someone elses fuel going in.
For all the westies on here, next time your going over the bridge take a look down to the left in Mobil where the tankers park and notice the different brands all parked in the same place. Then notice the huge tanker painted up as BP ULTIMATE in the middle of Mobils property. (same tanker was painted up as optimax couple years back)
I said earlier, they all come out of same refinery but I should have said terminal, that being the Mobil Yarraville one but each company still have their own refinery. Mobil are not the sole creators of all fuel as you said Shell is in geelong however BP's refinery is in WA. The Mobil refinery in Altona delivers it's fuel to the Yarraville terminal via pipeline. The terminal (under the westgate bridge) is co owned by BP which is why you'll see their trucks in there. The fuel get brought into the tank farms via pipe (shell and Mobil) and via ship for BP and interstate and OS fuels.
Bonus for the Mobil terminal is it is on Preemo land that it has had since the 20s, it's right in the shipping lanes.
*puts on cheesy Starship Troopers Narrative Voice* "Would you like to know more?"
More about Fuels
Some interesting points above.
I work for the parent company of the largest fuel and gas distributor (80%) here in Oz and have done a lot of work with BP, Shell and Caltex directly hence why I receive their schedules daily. One of my projects has been automating them via a custom mobility solution to each truck.
The trucks you see below the Westgate bridge are ours, that is our Spotswood depot. We have trucks labelled with our company name, the parent company name and also the customer's name e.g BP & Shell.
Interesting link above, thanks for posting.
In reguards to saff cossie post, I actualy saw 2 tankers / trucks, taking the BP Ultimate fuel on the Westgate bridge this morining at like 3-4am today.
I think Doncaster and Templestowe BP still had the Ultimate in stock.
QUOTE (SS8_Gohan @ 11 Jan 2009, 06:36 PM) *
so you're saying your can runs better on a lower grade fuel? right...
He probably uses cooking oil in his engine and dishwasher liquid in the radiator too tongue.gif
Cars not designed to run on high octane fuel and not TUNED to run on that fuel can run better on lower grade fuels. Why is this so hard to beleive. I think the marketing guys at the petrol companies have done a great job convincing ppl to run fuels they dont need.
i saw R34 and thought turbo, and the sticker on my car says 98 or higher, so i would say that is what it's "designed" for. Considering Japan gets even higher grade fuel, i would have thought 98 is where you want to start
I heard that you can get 100 octane pump fuel in Japan. I know a few years back there was something called Shell Optimax Extreme or something, rated at 100 octane but it had 5% ethanol in it.... Can we get real 100 octane in Oz?
Shell V Power Racing is/was 100 RON but its getting harder to find it now. Punt Rd Shell used to stock it, it has the ethanol in it, will chat with the guys and see if we still deliver it as I havent seen a schedule for it for a few weeks at least. :P
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
