I used a heat gun to slightly heat the yellow section then just flicked it off with a screw driver it should pop off does a little bit of force. What your left with is the same metal part showing on the standard 26 injector in the picture. You then need the new pintle cap thats suits the indy injector which just pushes on then it will suit the standard rubber on the inlet manifold... Hope that makes sense
Makes sense, thanks. I've emailed injectors online regarding the 11mm caps, see how we go.
I grabbed a 14mm rail from mrparts for the others considering machining jap rails. Quality looks on par with the hks rail it's replacing.
highest i have seen so far is 427 out of a 0.82 on E85. (NYTSKY's car)
My evo isn't far off that with a .63 and vp109 :devil:
cosworth 2.2 stroker kit billet crank option
full port polish 1mm oversized valves big cams standard intake plenum and throttle body
6 boost manifold tial 44mm standard off the shelve .63 GT35 from garrett 3inch dump pipe 3 inch exhaust
plazmaman cooler
2x 044 2x -8 feeds to sard rail 1000cc inj -8 return via PFI reg
29psi boost
any news on how the new head performs?
Sorry mate, i was a bit premature. still building the new fuel systam atm. If all goes according to garp we should be on the rollers on thursday or friday.
Got a lot of conflicting info on fuel line compatibility with e85 so to be on the safe side we are changing out everything except the fuel tank.
Noel's new fuel system includes:
2 x Pierburg fuel pumps flowing 6.5L/min at 5bar
1 x 4L surge tank
2 x cleanable fuel filters
-6 hose in boot and complete underbody hard line mounting in -6 fuel line. 1 line for each pump
6 x New Series Indy Blue injectors ( not the old style ones )
1 x Tomei fuel rail and a whole bunch of fittings that Noel cried about having to buy again :D
1 x 4L surge tank
lol the old girl :D
Whats the vapour odour like?
Nice big tank
Still got rego?
Certainly does. A surge tank is only an extension of the factory fuel system. We have engineers approval on that and a blue plate just in case :D
lol the old girl :D
I'll tell you when we start it :(
lol the old girl :D
Watch it pup
Dan - where do you get the Pimps from?
Edit - oh wait, pumps* lol
But I am sure Noel is a Pimp, his car is way too nice for him to have a legit job :laugh:
Pimp daddy pumps from either ERD or EFI Zeb.
Me thinks they are going to become very popular now that e85 is becoming more available.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
