Did it make it off the dyno?
Yeah it had been running for two days no problem on the street. Did (I think) 3 drag runs with pauses in between on the Saturday. We checked the spark plugs at the stop over and everything looked sweet - still does
Then Noel did two back to back drag runs and it died at the end of the second run
just thinking of that Dan/Noel, have you tried adding a few degrees of timing, might lower the Egt's enough to help the turbo live
Yeah there is 18degrees in places where 0 degrees used to be so I am told. The tuner has a lot of experience with E85 and Methanol.
Don't falcons use the same gt35 with a 1.06 rear and make 400rwkw all day with a 4L motor without cooking them?
yer my falcons been running 500whp for years with the stock turb. 15psi bp98. the magic number for these is 19psi, turb will last 4ever at that boost or below on 98. they only rev to 6500 tho, e85 + high rpm and the .82 housing ....
this may sound stoopid. but because of the extra heat e85 creates and considering its going to be a popular everyday fuel in the future, do u think some sort of water injection at the mouth of the collector on the manifold would ever work ? it works on the combustion side ?
After some quick searching:
"You all really need to check you EGT when adjusting timing map with E85 because E85 burns much slower then gasoline you will almost certainly run very high EGT temperatures when you switch to E85.
When I started mapping for E85 I quickly saw the EGT rise to over 1100 degrees Celsius, we added more pre ignition timing and the temperature went down. I now have 32 degrees pre ignition on full load and about 870 degrees EGT.
Your piston rings or conrods will probably break before you hear knocking on E85 :-)"
From here: http://forum.nistune.com/viewtopic.php?f=7...623&start=0
"We have come to the conclusion that running an old truck technology TO4Z exhaust housing is probably part of the problem, and are upgrading to a GT series turbo (unfortunately as the TO4Z worked amazingly well) which apparently can withstand higher heat loads."
From here:
http://www.efi101.com/forum/viewtopic.php?...1e463c6bdd43846
back from a few days r&r with the mrs. Interesting reading these last few days.
I dont have the answers. matter of fact i dont have any answers. I do know i am way tired of the 35r's shitting themselves and takin my engine with them. It gets old very very quickly. And if you think I'm tired of it spare a thought for Dan, I'm sure his heart sinks lower than mine every time the friggin turbo lets go.
The response from the turbo supplier has been abysmal. Whilst they openly admit we have made out turbo selection well within the guidelines of their criteria Their only recompence was an offer of "A very good deal" on a new turbo. Not happy Jan!
The next turbo to go on the car will not happen until we have exhausted every research avenue in an endevour to eliminate this bullshit. The only definite change atm will be an upsize from a t3 to a t4 split pulse flange. Will keep you posted when a final selection has been made.
From here:
Most definatly that can be the case. The question is, Are the high EGT's from overly retarded timing? Or is it directly related to the fuel? What where the EGT's on pump gas?
Where are they measuring the EGT's. At the collector or out of the head?
Ill think you will find that is at the collector into the turbo. This is going to be your highest reading because of the high pressure area.
E85 directly does not cause High EGT's. Going from 98 to E85 a 100deg c drop in egts at higher power levels are not un common.
The slow burn rate of Ethanol. Is this the same "slow" burn rate as Methanol, or Elf race fuels? They both have amazing low EGT's so how would E85 run any differently?
I have seen many logs of different engines on differnent fuels from 98 to 109 to 98+Meth to 98+meth+Toulene to E85 and even straight methanol. E85 Does not always make more power, It does how ever have the lowest EGT's.
Edited by HYPED6
Yeah point taken its not a direct comparison but I understand the car we are talking about hasnt been doing laps and laps to bust the turbo either? Did it make it off the dyno?
Personally I think 20-22psi through a 1.06 housing will bring the temps down enough but I am not going to pay if it doesnt so I will be quiet.
The turbo had done 3/4 months of track work prior. That seems about the life expectancy of that combo.
No becasue the oxygen in the water after it evaporates will cause any flame front int the exhaust manifold to..well....make a very large bang.
Hey Zeb, can you explain this please?
Are you referring to dissolved oxygen? Because surely the dissolved O2 wouldn't be significant compared to the O2 left in the exhaust gases after combustion.
And water itself doesn't break down into hydrogen and oxygen until 2000oC.
Water is a natural product of combustion:
(Ethanol) CH3CH2OH + 3.5O2 -> 2CO2 + 3H2O
Petrol is similar but a much larger and more complicated hydrocarbon.
Cheers
Cheers
I was more refering to the rapidly expanding gas and the huge heat shock it would cause, like a 600-700deg exhasust manifold and then spray some cold water into it
Edit - oops still signed in to Prues account lol
Zebra
    • Meanwhile, 20+ years ago, I pulled out the 105mm hole saw and went straight down through the inner guard in front of the airbox to get my stormwater pipe cold air intake in. Right behind the two stock holes for the intercooler pipes. Those have no reinforcement (apart from a couple of robust pieces of steel pipe through them!). I feel that the Australian vehicle standards crews put way too much emphasis on "maintaining the crash performance" of cars and not enough consideration of "any crash is a new and wonderful experiment with a random selection of parameters and you will never be able to tell if an extra 80mm hole through some sheet metal caused a significant difference...but if you close your eyes and squint at the whole structure, engage your engineering brain and have a good think about it, you'd have to expect that it would do jack all."
    • You guys are focussing on the wrong part of this post and have headed off on an irrelevant tangent!  Clearly I'm not going to put my most prized physical possession (well it will be once I'm finished it...) on a piece of shit contraption that might fail and crush me or my car!  At no point was that even implied I was trying to buy a butchered P.O.S that some shonky clown had thrown together with a gasless MIG....  Either way I would love to see the build quality of a rotisserie that has failed.  Actually I'd love to see a photo of one that has failed full stop.  Google fails to deliver.  Never happened?? I'll either make one that won't fail or will buy one that wouldn't fail! End Post.....
    • Yeah, if you can't breathe for more than about 2 minutes, you're cooked.
    • Well, all the power should be getting dissipated across the starter motor. Therefore, ideally, the voltage drop across the earth lead should be convincingly close to zero. Certainly you'd want it to be only a volt or so at max, because otherwise that volt doesn't turn up at the starter to do what is required. A car can probably survive a bad enough earth to crank and start with only 9V or so at the starter motor, maybe even a bit less. But you're seeing only 8V at the battery terminals when cranking, so there can't even be that much available over at the starter, which simply won't do. I would have thought that you couldn't pull enough current (with a healthy starter) to make the battery drop to 8V locally. But I was ignoring the possibility that the starter is in fact crook. If it has shorted windings (or maybe the solenoid is borked and shorting to earth) then I guess it could pull a stack of current and not even look like wanting to turn over. So follow the other boys' reccos too. Because they are just as likely at this point.
    • Depending where the whole gets drilled, and what country/state you're talking about, quite likely not.   Under ole vehicle mod rules in NSW, VSI06 allowed for drilling of holes in "non structural" areas. So you could drill a hole through the inner guard, and not need engineering. You couldn't drill over seams, and it was advised to add extra reinforcing around the hole, as well as something to protect from sharp edges.   Again, it's all about finding the documentation for where the mod is to be done, AND then being able to explain the situation, with the documentation as to why you don't need engineering, with a positive attitude, to any one of the likes eg, police, vehicle inspector, etc.
