Even @ 330rwkw on E85/.63 - that is pushing then limits of believable. But at least its almost believable rather than outright fudge.
Maybe low 20's its believable (330rwkw that is). A 3582 .82 wouldn't make that much "claimed power" at those boost levels on E85.
you know trent from status uses the same dyno... with the same calibrations, and has had similar results on customers cars with a similar turbo set up?
everyones quick to jump on the dyno debate. If we had a drag strip in SA i would seriously consider it... with previous tune of 360 rwkw's i managed a 1:18 flay around mallala in a drift car on street tyres. this was beating 330 rwkw gtr's that were done on a mainline dyno (willall) so clearly some of you need to pull your heads out of your arseholes and face reality that such results possible.
ever think that maybe mainlines read low? I had an RB20 r32 ages ago with a 25 turbo on it with an EEPROM chip remapped. made 148 rwkw on a mainline.. where as on a roller dyno (DD) it made 180 rwkw.. and on the AMM hub dyno made 185 rwkw with the same correction metiod.
19psi though mate...
5557 .63 made that same power (roughly) on >30psi of boost. Albeit on a 2L SR engine, it's still something. Why do SO MANY people make around the 300rwkw mark on 1psi less? Surely there isn't 90kw difference in reading between the dynos....
Just know that it's all about how much you enjoy the car, and how well it performs - a dyno is simply a number, and doesn't mean ANYTHING in some cases. This is one of those cases...
the whole point is that a 3076 cant push enough air to make 400rwkw.
and its very misleading to forum users that think they can go out and get a 3076 and make 400rwkw its just not goint to happen. its a 300rwkw turbo with E85 you can get 340-350rwkw out of them thats about it.
yes your correct becuase thats exactly what it did.....
the car in question was initially tuned on this dyno by amm using those exact corrections so i gave simon that graph today purely as a direct comparison to how it was before. the result be a 40odd kw increase over the previous setup. i had no real choice there.
i did todays whole retune using more "roller correct" corrections and in actual fact it produced 357kw. i dont think that turbo is gonna do too much more and i had no interest in trying. the result was great as it was.
at the end of the day, its a tuning aid and a VERY good one! the 397 was merely a reperesentation of todays gain.
I don't know what dyno it was on, but I remember recently someone pushing around the 400rwkw mark from a 3076 of some kind, but on a ridiculous boost level around 30psi - WELL out of efficiency
i bet they'd find that if they dropped the boost and tuned it accordingly, the loss would not be dramatic.:thumbsup:
I must have the wrong thread here I thought it was the 400rwkw thread, not the 390rwkw thread. Can anyone link me please? :whistling:
Lol, so true.
Im pretty sure the dyno blew up when he recorded a power level of over 9000
Edited by Nee-san
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
