  • 3 months later...
Theread revival time. back on the dyno yesterday for some preliminary work and promptly spat out 450 hp at 13 lb.Serious time gets serious next week.
I think I'm gonna love the new turbo.
Time for some big power Noel! Keep us updated.
Whats the setup again?
I can't remember... Perhaps I'm getting old? :rolleyes:
Absolutely not. The aim is for same power but more reliable at those power levels
GT3788R, RB2530, Wolf V500, E85, Bosch Black 1600cc injectors etc etc.
Boost response on the 3788 is virtually identical to his 35R. The lines literally trace each other
Very interesting to hear about the GT3788Rs being that good, I had wondered (thinking the GT40 turbine was a bit overkill on the GT4088R for a "small" motor")... Look forward to hearing the final results, sounds promising!
Wonder why those turbos aren't more popular, they've been around a while now.
They have been super popular. New turbo design. They are only about 1 year old technology now.....well, to retail
This thing sees 20psi before 4k - approx 3800-3900
Not many results around would be the main thing.
Ive always looked at them as an alternate to a T04Z but too hard to find meaningfull results
From what we heard before we put one on Gervase's 33GTR, the XR6 guys were replacing Z's with them and gaining about 100hp at the wheels and 400-500rpm better response
Gervase took off his 0.84 T04Z and put on the 0.89 GT3788 and gained about 400rpm response and made (I think) about 80hp at the wheels more on the same dyno.
This is the 4th one of these turbos I have fitted now, every single one is as responsive as a 35R or around the same but makes 150 odd HP more at the wheels depending on the application of course (mostly 25/30's or heavily modded 26's)
Is that including going from a single entry GT3582R to a twin scroll GT3788R? They've been around for quite a while, I think I gave up on looking for results for them over a year ago - so if there have been a bunch in the last year - that explains that. Looking forward to seeing the final tune results for this!
CAR: nissan stagea 260rs
engine: RB28
engine mods:
N1 block
full hks step 3 stroker kit (crank, rods pistons)
garret gtx4294r turbo
tial 60mm external gate with screamer pipe
hks gaskets
hks timing belt
hks cam gears
hks fuel rail
hks 1000cc injectors
hks oil pump
n1 water pump
trust sump kit
tomei 280 degree 11.5mm lift drag cams
tomei drag valve kit
tomei titanium retainers
tomei valve lifters
race cut valves
race valve guides
arp head and main stud kit
trust PEII 3" exhaust
koyo race radiator
100mm intercooler
2x walbro 255 fuel pumps
sard FPR
POWER:
have to change exhaust so power is "restriced" to:
580hp@18psi on BP98
710hp@23psi on 109 race fuel
Correct Lith, it is a twin scroll setup. I keep looking up sleeves for hidden cards but at this stage it is showing remarkedly similar boost characteristics to the 35r single entry. Its only running gate spring pressure at this stage but until the gate starts open on spring pressure the curve is identical.
Waiting on a wide band sensor to arrive and then we'll hook the boost control up and go to town on it.
Pretty happy budgie so far.
Interesting indeed.
On dyno/loaded/4th i take it?
Any ETA on that? Surely it cant take long
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
