EGT's are and must be measured out of the head and on each cylinder. If say cylinder 4 gets too hot and the rest are ok, then richen up just cylinder 4 under the boost levels where it is a problem.
Get it within where you need it, and keep tuning knowing your number 4 piston is safe and happy and you can keep leaning on your cast pistons.
Have a look at this video. Its not an RB but still a cast piston and standard 2.5 probably made in the same factory as nissan pistons.
This engine eventually died from a broken rod bolt after the owner held the engine over 9000rpm for about 15 seconds doing a skid.
All the pistons where perfect after 2 years of abuse with power levels of around 650rwhp.
EGT's never went over 800c when raced ;)
O yeah. Watch the dyno on the first run....... then watch me crap my pants.
Yeah pretty much what we all do at some stage or another,
Willowbank a number of times. 10.2 @ 145 was the best. A lot of spirited street driving and power cruise's and track days at queensland race way.
The car wasnt diven every day, but is definatly a testiment to what can be done to a standard cast piston when achieving 400rwkw.
Yeah thermocouples.
A heat gun will only tell you the component temp of the exhaust manifold.
A thermocouple will tell you the gas tempreture inside the component.
We use a tempreture logger with 8 channels the plugs straight into my laptop. They are pretty fast and super accurate
Edited by HYPED6
Thats correct. We use a 5mm metric thread in our sensors and just weld a nut on each runner.
It does sound like a pain, but Id rather pull my exhaust manifold/manifolds off than clean small pieces of melted piston out of my sump.
Most people just include it in there next build or turbo up grade.
For our setup we paid around the 2k mark. That was a few years ago now. The sensors have had a flogging with almost every fuel you could think of and they are still perfect.
would it be possible to make a sandwich plate with egt sensors in them?
How big are the sensors?
Edit: 5mm
You must have posted as I was typing
Edited by zoidbergmerc
Similiar to on my car Rolls, whether you saw or not?
In front of the windscreen you can see them bundled up.
You drill and tap a hole in each runner, pretty well same distance away from port so temps are equally measured. Actually I guess only if the runners are thick enough, otherwise weld on a nut or machine up a bung and tap a thread in that and weld it over the hole, which is what I did with my extractors.
My set-up was under 1k when the dollar was pretty weak, only downside is the outputs can't be fed into the ecu so I have to log egt separate to everything else. The kits come with everything you need inc the bungs, no need for custom bits.
Where did you get your setup from...?
where did you get the kit from ??
Edited by tricstar
Fail! 3&1/2 inch dump is restricting. New dump on the way. Do it all again.
sigh....
Go 4" Noel and wind it up!!!!! I did a quick search and it seems no one has really taken the plunge and gone with the GT3788R.
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
