lol, you mean lucky me? surely PI isnt that hard to get a car into??
yea i like that... but that goes on glass, is the one for behind the driver, mounted on the cross bar of a cage?
lol sorry what I meant is that any magazine article done on your car is a good thing, not everyone can say their car has been in a magazine :)
That mount can go on panels outside also but i know what you mean, you need one with a ring grip on it yeah? like these - http://www.camzilla.com.au/products/clamp-mounts
  • 1 month later...
Bumping this thread; a current 400kw club member got off the rollers last night with a slightly higher reading than before. The car is an animal now!
Anyone else breaking into the 400's lately?
I'll only list a few of the major mods
R33 GTR motor
Cp pistons
Eagle Rods
Tomei oil pump
Trust 264/272 cams
Tidy'd up head ports
Arp studs through out the motor
Precision 6765 still with T3 rear housing .82
Haltec ecu
1600cc Indy whites
442kw at the wheels on 26psi.
I've now ordered at T4 divided rear 1.00 so should make some better numbers..
Edited by 26_S13
Holy wheelspin batman!!!
With normal street tyres yeah, just cruising along in 4th and put ya foot down it would start baking as soon as it come onto boost.. But with 275 Micky t ET streets it hooks up and goes, cars not manual anymore though, just bought a 2 speed for it.
Our race car cracked 441rwkws/592rwhp the other week.
RB30DET
6boost mani w/ gt35r 1.06 rear 45mm progate.
STD gtr plenum & throttles adapted to 25 head
Domed CP Pistons
Custom ring set
Spool I beam rods
Kelford 264in/272ex 10.2mm
Light Port work
1mm oversize inlet valves, 2mm oversize ex
bosch 2000cc squirters
Running off gate pressure cracks 23psi by 4000rpm from memory and then bleeds off down to 19psi by redline @ 7500. Peak power is around 6500rpm at about 20psi. Need to hook up and setup a boost controller to hold 23psi to redline.
Not a bad effort for a 35r. I will try and find the printout, though I think my old man has it somewhere.
Sorry that was using straight methanol.
Yeh it did it quite easily too. If we can get it hold the 23psi to redline, I would reckon it would easily crack over 600rwhp. First run it was at 17psi which for some reason it could hold to redline, Im guessing back pressure was at an equal level to intake pressure so the wastegate could manage it at which it made about 510rwhp. Then I changed the spring setup to a 24 psi combo and it only went to 23psi and bled back as I was saying in the other post. But at only a few psi more then the previous run it oozed out another 80 odd hp which was unexpected.
The great bit about the alcohol is the car stays nice and cool, water temps stay in check, oil doesnt get warm enough which is actually abit worrisome and the inlet manifold is cool constantly with the fuel rail chilly. It is amazing stuff.
    • Hi, does anyone know how I can, or can a moderator remove this advertisement please.  Has been sold a long time ago and would like to remove references. Thanks.
    • There are adaptors that allow you to delete the booster and use an s15 clutch master cylinder.    if you want to keep the booster they are still available brand new
    • I visited again today: It would appear they have painted the main body of the car and some parts of some of the panels, so I can say that I now have BMW parts in my car, much to the envy of @Dose Pipe Sutututu It is still covered in dust which is quite the tease but I did look at a few circumspect spots that will be behind bumpers and such and wiped some dust away: After my repeated begging to PLEASE DONT PAINT OVER THE ENGINEERING CERTIFICATE (you have to re-engineer the entire car if they do) I see THIS: Which is great. Excellent job tbh at least to me. A better non dusty example would be the backs of the doors that have been painted: Giving a reasonable contrast between old and new (I know the old isn't clear coated on the inside of doors). The door card will well and truly cover where the old paint is, you can see in the second pic some of the black butyl/whatever shit is sticking the plastic sheet behind the door transfer that has happened since it's clearly been stuck back on. The most maddening thing about this colour is every time I saw it in the wild it looks like another colour, same with photos of many cars with the same colour looking wildly different in every photo anybody ever takes and this is no exception. But stand a little further back and it suddenly looks dark AF. I did tell them when I was discussing which of the 70 million charcoal colours to choose from (a porsche one, a BMW one, or a R32 GTR one etc) that if they just ignored me and chose one at random I would probably never notice. Maybe they did. But the colour is supposed to be B39 (BMW Mineral Gray). Boring I know, but the R34 sedan (to me) really shows off it's boat-ness when you paint it in a bright colour like bayside blue or white or whatever else. I do have a fondness for AR2 Nissan Red, but decided against that because it'll have pretty odd contrast to random bits unpainted (like engine bay, bits of trim etc, and maybe it'll fade). And people will always fkin comment on AR2. Everything remains super dusty. I have tracking numbers for the new heads, as well as some Improved Racing goodies, but they probably will be a next year thing by the time they end up on the car. I did some maths on the heads and I know why nobody goes to this extent in Australia, because it's really not worth it, given I could have just CNC'ed my current heads, bought a FAST102/TB and used my current rocker/spring/cam combination and get a 383 stroker (or stroked a 6.0 GenIV bottom end to 6.6L) built for the same price of just the setup in the mail/on the floor here. Or I could have bought a LS3 and a Drysump system. And then have a complete engine to sell. Oh well
    • We just disconnected the vacuum line if I remember correctly, booster is still there. Is there a rebuild solution for the booster or a different adapter that will work for GTR chassis?
