  On 28/10/2011 at 12:15 AM, zebra said:
Any idea what mixtures it was running mick?
I would have to check the printout, I have a feeling it was around the 8-9 mark, the scale started at 9 and it was below that lol.
Actually, its not as bad as you think it is. We were on the dyno all afternoon, probably 3-4 hours straight and we only used about 20 litres. I filled the tank right to overflowing thinking we would chew through it all, came home and tank was still 2/3rds full.
  • 2 months later...
Another happy Unigroup customer just joined the 400kw club. User name mlr
He only wanted 500hp but the power bug got him haha. This car has HEAPS more in it; injectors were maxed on pump 98, so he's got a list and will make changes then go back for more.
  On 28/10/2011 at 2:36 AM, r33_racer said:
I would really like to put as much boost through it as possible and see where the 35r's limit is....I wonder if 700rwhp can be achieved lol.
You can probably get away with running more boost in the midrange once you find the limits. Eg 20psi at redline is more air than 20psi at 4000rpm, hence if you are maxing it at 20 @ redline then you should be able to get more flow in the midrange.
have to look at the compressor map to find out how much
Edited by Rolls
Well done mate. :D
The last run, did it make anymore?
Still at the exhaust shop mate...plumbing for the gates and the hot side of the turbo is stuffing them about... That and they ve been on holidays up until Monday the bludgers
Edited by GTR_JOEY
  On 10/01/2012 at 9:03 AM, Piggaz said:
Well done mate. :D
GTSTRB25/30T04ZRWDFTMFW x 11TY
Im wrapped, and no thats all she got, the injectors were at 85% so didnt push anymore, list is done, part one will start soon to get more fuel and better air flow then latter in the year E85 flex fuel thingie and associated stuffs.
ID2000, sounds like a computer game, LOL
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
