+1 Dave. So sick of the "how do I raise my boost for free" shit threads and people wanting mega power on a shoestring budget lately!
How's your setup coming along for power cruise? Give us some good news!!!
Matching turbos and supporting mods to achive a practial/streetable Car has nothing to do with "raising boost for free" or even a budget for that matter, Our cars are money pits No matter which route you choose, Just aslong as you have fun with it
Practical street car talk is over here;
http://www.skylinesaustralia.com/forums/topic/236467-definitive-guide-to-building-300-330awkw-gt-r/
Enjoy! :) (Not being rude, but anyone in here with 400kw doesn't really give a shit about practicality)
Getting some stuff done at Speedfab, should be back at JEM by the end of the week to get all bolted up.
Cutting it fine as usual. :rolleyes:
Got to admit, you're consistent haha
Havnt heard of speed fab before-tell us a bit about them?
His name is Rob, PJ put me onto him. Did all of his metal fab stuff.
He made a manifold for a customer at JEM. Top notch stuff, so he made my new one, shroud for thermo, a bit of pipe work.
So yeh, fingers crossed it all comes together in the next week or 2. It will be a car to keep your ears open for at Powercruise :)
I would just like to have some more time behind the wheel in between breakages. :cheers:
finally cracked the 400 mark
r33 gtr 1995
rb26
engine
honed/bored 0.20# , acid dipped all usual machining done ect
shot peened n1 rods with enlarged big end bearings , crank balanced re nitrided and oversized 0.60 acl race bearings
arias 0.20 over pistons , acl piston rings
tomei oil restrictor
tomei sump bafffle/trap doors
N1 water pump ,
s oil pump
genuine nissan gasket set throughout
cossworth drag series 1.5mm metal head gasket
head reconditioned with porting on exhaust side , hks 264 cams greddy adjustable cam gears
arp head stud kit
driveline
Very rare Autogallery yokohama 1-5 H/D set with double cone syncro's , redline shockproof oil
Os giken pro series twin plate push type clutch
Vspec rear active lsd diff
Turbo/exhaust/intake
Trust greddy t517z turbos with 10cm housings
standard manifolds match ported
hks non turbulent dump pipes
custom twin 3inch y pipes with 100cfm race cats y pipes individualy run to centre of car and then merge into 3.5inch exhaust with highflow muffler and 5 inch tip
apexi hard pipe intake kit with twin z32 afm
electronics/ignition/fuel
apexi power fc , with hand controller
blitz 4 stage electronic boost controller
bosch single 044 mounted intank
injector dynamics 1000cc injectors with convertors t fit 10.5mm standard rail
turbosmart adjustable fuel pressure reg
splitfire coilpacks
hks twin spark DLI amplifier
low compression engine tested 128- 132 across all 6 due to 1.5mm h/g , current power 405kw@wheels on mainline dyno at 23psi fuel pump is probably near its limits but this is plenty for me!!
Good result man! No spark issues with the Twin Spark?
Prob a bit more left in it with a little more boost!
by installing your hks twin spark and splitfires and adding 3psi gained 55 kw atw f*kkn redicolous gains lol , must have been missfiring somethiung fierce before!!
r33 gtr 1995
rb26
engine
N1 water pump ,
s oil pump
arp head stud kit
driveline
splitfire coilpacks
How do you find the gearbox? Have you driven the Os Giken one to compare it too?
That should be in the title. A disclaimer like "if you're after response, do not click this thread"
LOL ye not like people are running 540ci motors.
Some results in here are pretty damn decent for the power none the less.
Its all about the number nismoid. This thread isnt about response haha
It should be. Why would you not want your cake and eat it too?
Noel makes 24psi by about 3500rpm from memory and he doesn't even have the VCT back on it yet. Correct turbo selection and head setup and you can make 550-600hp and still have good response
    • Hi guys looking for a r33 Gtst stock exhaust asap in Melbourne have $$ waiting thanks
    • Jump into the wasteland. Plenty of random posting/chatting going on in there.
    • I did not go to GTR Festival. It's quite a long drive and the car wasn't dialed in yet. I also wanted to see how the racing portion went before going. From what I can tell the classes were not heads up, index, or bracket - just whoever has the quickest ET wins. Never heard of that sort of thing before and maybe some people like it but it's not my cup of tea. I don't suspect I'll go if that is how the racing is done. I did get the car out three times and had issues each time. Some were my error - haven't raced the car in over two years - and others were parts. Had trouble getting the clutch to slip correctly and remembering how it was set up in the Haltech. Broke some drivetrain parts as well that couldn't be fixed in a couple days to get back out. Season definitely didn't end the way I wanted but at least the bearings are still fine! Not a fleck of material in the filter. Really hoping next year is the year I can actually test this car properly.
    • find it funny everyone claims different fuel chains, do different things with their fuel blah blah blah. We don't have that many fuel terminals in Australia. The fuel tanker trucks drive into the terminal, fill up, and drive directly to the service station and dump out. The majority of fuel you get, is coming out of the same terminals. The variation is actually at the individual service stations and how good their tanks are, as well as how much turn over they actually have. Older fuel stations, that haven't had their tanks replaced are going to end up with the worst fuel. Also a lot of older stations have shit design, and shit maintenance, and end up with more water absorption into the tank. This is when you then get a bad batch of fuel. Other shit things happen, like tanker drivers have a f**k up, and starting to unload the wrong compartment on their truck into the wrong tank.
