Got Over 400kw Atw?
T04GTR
Have there been many results with the gtx3076r around the place?
I dont think on here.. I know the supra forums have some results, and also the S2K guys have some results too. A search in google gave me a lot of BS, if i have time later when i get home i'll post the links.
Have them in favourites on the lap top :) on the phone atm, sorry mate!
Marko - thanks for the reply. I'll go through and have another read, i remember reading that they are stock items in AMG's, etc? The flow rate is awesome.. Price isnt too much of a drama, would rather hold out a bit longer to get good equipment.
Feel free to post up how you go fitting it :)
Dajae - I bought a pierburg but haven't fitted it yet...I created a thread on my findings and what I can tell you is that it flows more than the aeromotive stealth by a decent margin but I can't recall the figures exactly.
As a comparison, Bosch 044 flows 200ltrs/min @ 5bar whereas the pierburg flows 360ltrs/min @ 5bar.
They are not cheap so expect to pay about $450 with a filter.
You wont regret it. I am running 2 of the suckers and together they are quieter than one walbro or bosch.
Great stuff, do you have them intank or external? How did you go about fitting them, not really a drop in? I had a quick search, but only found discussions on the use of them, not so much the fitting etc. My walbro is fairly quiet (although I dont really have much to compare it to), so if its even quieter, fantastic!
Veyron.. 4 of these pumps all together isn't it?
Ok, so some results for the GTX3076R .. Turns out it probably can flow enough for ~400rwkw :) but with all things, we should take this on board with some speculation. I mean like seriously, a Focus with over 400fwkw... With an intercooler the size of a cereal box? C'mon... Lol. Ok, enough jibber-jabber, linky time!
http://www.nissansilvia.com/forums/index.php?showtopic=497486
^ Bit of a comparo with a GT3076R.
^ The focus with 600whp..
http://forums.nasioc.com/forums/showthread.php?t=2110277
^ Fairly good write up on some of the GTX range. You can see here why I'm pretty confident of the GTX3076R hitting ~400rwkw.
^ And finally, an RB25 making 534whp. I know, its not *quite* 400rwkw, but farout it's close! Awesome stuff.
I'm drooling at the thought of getting one now.. :D
There is no way that 240SX belongs to that dyno graph. Have a look at the way it ramps up compared to the power line.
There is also a very very very slim chance you would ever get a real 530rwhp from a GTX3076 and not on 26PSI.
On 20PSI the GT3076R is lucky to crack 300RWKW. 6psi more and a 10% more efficient compressor does no equal 130hp at the wheels. I'm betting methanol or nitrous help if the figure is right
On E85 I can fully see them hitting 400kw, as I've already said. On pump gas, I'm pretty confident of it NOT happening. You don't need >60lb/min of flow to make that kind of power when using flash fuels though.
a lot of dynos in the UK (if thats where the focus one is from) give readings based on some crap math for "flywheel" hp
Definately have to take this results with some sceptism, but the potential is there.
Lith, agreed with e85 400wkw would be achievable. Hopefully when r33_racer (sorry i dont know your name, im quite a n00b to the skyline community) gets the gtx on the 3.4, will see some similar results. Anyway, enough of me hijacking the thread.
Thanks for the input guys :)
Agree on the 240sx. To look at the car on the dyno it's hardly straining the dyno. To make that sort of power with a 4th gear run your going to be making upward of 8000N of tractive effort. When you are making 8000N you can tell that the car is wanting to leave the dyno - that car is barely moving on the dyno.
I don't believe it will be impossible to make 400rwkw with a gtx3076r but you will need high octane fuel min 105ron. And your may need to increase the cr to help the bsfc.
Edited by rob82
What makes you think it might not?
They take alot of meat out of the block to fit the 3.4 stroker. Have heard of a few blocks not holding up for long.
Have u tested one before?
Only what i have been told never seen
    • Define "Nissan big brakes". You just mean standard R34 4 pots? And...it's not even the offset you need to worry about. It's really a detail of how much clearance there is between the caliper and the back of the spoke/face, which is affected more by the design of the spoke than it is by the offset. If you think about it....take any wheel, say a 19x8 that does fit and clears the caliper. Then add or subtract an inch of wheel on the outside, without changing anything else. You have changed the offset by half an inch, but not changed the clearance situation at all. Same for if you add or subtract an inch from the inside edge. The way for you to work this out is to take a wheel off the car, grab a straight edge and a ruler or two, and start to measure the distances from the wheel mounting face on the hub to the outer face of the caliper, and the outer diameter (that faces the barrel of the wheel) of the caliper. Armed with these dimensions and any other measurement that grabs your fancy while you are there, you can then go to the seller of the wheels and do the reverse measurements from the wheel's mounting face and see if there will be clearance to the caliper. There really should be. I have 17x8 RPF1s +35 clearing the caliper face by a finger tip. Those wheels do have pretty thin spokes with some curvature.... but then so do most wheels to suit Jap cars.
    • So I’ve got a r34 sedan that I managed to get green stickered, meaning I need to go through government approved wof station for my car to be allowed back on the road for some reason my car is certed for 19x8 rims.. I need these wheels  does anyone know what offset will be fine to clear Nissan big brakes? I saw 35et for sale near me, I can’t drive the car to test fit or risk being fined ..   I searched heaps online couldn’t find anywhere..
    • Okay, with all that being said about sloppy blowing from twins, I happily acknowledge the superiority of a single turbo setup on the RB; however, I still plan on double trouble.  I know the -9s were quite popular for some time because they seemed to meet that sweet spot between the -7s and 5s, would introducing VCAM and/or stroking to 2.8L provide the additional displacement/flow to push twins closer to the 500-600 goal?  Does it make more sense for a daily to just do an engine overhaul, slap some -7s on it and enjoy a bit more reliable power?  Has anyone driven a mine's overhauled and tuned engine?  I know they certainly don't approach the power numbers that you drag monsters do down under, but for daily street usage, I just want it to be fun and healthy.
    • Mmmm. Perhaps more correctly stated that the one turbo doesn't actually force air back down the throat of the other. All it does, and all it has to do, is be pumping a little harder than the other turbo (which is an effect of how the turbos are getting driven by the exhaust and inherent resistance to output air flow that each turbo sees up to the merge). If the turbo that is not flowing quite as much then nudges the stall line (because it gets pushed there by the higher flowing one stealing the limelight and moving its own operating point further from the stall line), then you get the behaviour described by Josh. There is no need for air to move backwards in any way. It just needs to be less air moving forwards than is required to stay to the right of the surge line.
    • GTX2860R Gen 2 is an option. No, it doesn't actually do much. The basic problem with wanting 600 whp out of the factory twin turbo setup is a few things. One is that the twin turbo piping is just so, so inefficient. The front and rear turbos are not actually working evenly. The rear turbo is always moving more air than the front. On top of this the OEM rear compressor inlet is rubber that likes to collapse causing a huge intake restriction. The merge doesn't even wait until the intercooler to happen, and it happens at a 90 degree angle. This is why you see some discussion about "turbo shuffle", where in certain conditions one turbo can actually force air to go backwards into the other compressor and stall it out, then once the other turbo recovers it stalls out the first turbo in a cycle until you do something to break out of it. The other issue is that the RB26 is just not that efficient an engine. It needs a surprising amount of ignition timing to reach MBT for a given cylinder pressure so all that time in which the cylinder is pressurizing before TDC is just wasted energy. An N54 might be around 10 degrees BTDC on a stock turbo getting into the boost. An RB26 is closer to 25 BTDC. Net effect is a turbo roughly the size of what HKS uses on the GTIII-SS (smaller than the R3/GCG Japan "GT2860-1" -7s) is only good for maybe 550 crank hp or low 400 whp while a roughly comparable turbo on an N54 can deliver something like 700 crank hp and obviously drivetrain losses are greatly reduced when you aren't burning a bunch of power on keeping a hydraulic pump + transfer case preloaded all the time. So yes, you can make a lot of power but there's a reason why people go single turbo for the numbers you're asking about. Don't forget that the RB26 can't even do a straight line pull without oil starving on the stock oil pan either. Baffles can help, but really you just need more oil capacity.
